Question about Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw
NO DISPLAY ON TV
THE CAMERAS ARE CONNECTED, THE VIDEO OUT WIRE IS ATTACHED TO THE BACK OF UNIT, VIDEO IN ATTACHED TO BACK OF TV. NO SIGNAL, NO RESPONSE ON SCREEN OF TV, NEED HELP TO MAKE THIS WORK.
  • 1 more comment
  • Anonymous Nov 12, 2007
    I have the same problem with a shr-1040. Everythings connected but nothing appears on the screen
  • Anonymous Jul 23, 2008
    I have evrything hooked up - The only display is the Samsung logo.
  • terryreynold Feb 20, 2009
    not getting any video outtput from samsung SHR 2042
I get a display on my tv from security camara but my vcr does not record.
Posted on Nov 25, 2008
Try restarting it pushing "mode + nº 1" button at the same time during 5 sconds.It is what it is said in the manual of : samsung digital vidio recorder sgr-2040p.
Posted on Dec 21, 2007
There is two outputs on this DVR, one is a VGA and the other is for composite Out. You will need to use the VGA and go in the settings to change it to Composite Out if you want to view it on your TV. Under settings>Monitoring>Monitor Out. Hope it works.
Posted on Dec 23, 2009
ON SCREEN HAD POWER ONLY V8.02.8
FOLLOW this instruction and fix it. God bless you
Connect the component video, HDMI1 or AV1 cable from the component device (such a DVD player) to the appropriate input port on the TV. This port may say "Video IN" on the back of the TV. Ensure that the cable is connected securely at both ends.
· 2
Use the remote control's device button(s) to access the menu and select the input through the menu that matches the type of cable input connected to the back of the TV. For example, if you connect the cable to the HDMI1 input port on the back of the TV, selecting anything but the HDMI1 option with the remote control may cause the "No Display" message to appear, which usually means that the TV is not receiving a signal at the connection input you have selected.
· 3 Turn the power on to the component you want to view. If the power was off, turning it on will activate the display and replace the "No Display" message.
· 4
Test any other connected components at their selected inputs to see that the TV is receiving the video signal properly from those sources.
· 5
Check with your cable or satellite provider if their set-top box is the source of the "No Display" message and is powered on, to see if the problem is caused by a disruption in their service. If using an antenna, adjust the antenna and re-scan for available channels.
Jul 20, 2013 | LG 55LE5400 55IN LED HDTV 1080P 120HZ 4...
Hi, no display in camera mode but displays works when playing the tape back,thanks Andy
In your statement since the LCD is moving there's miniature wire or ribbon wire attached to the folded LCD display. From thousand times you folded the display, the tendency of that ribbon wire will be crack, so mini switch that enable or trigger the transfer mode will not respond. So better replace it with a new ribbons wires. or call service personnel to replace it for you.
Jun 10, 2011 | Panasonic NV-EX3EN Mini DV Digital...
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
NO DISPLAY ON UNIT
Pull your display off wall and see if your unit has batteries. If you have a blue wire or, a wire connected to the "B" terminal in your thermostat(the part connected to wall, this should produce the power to show display. If you do not have a blue wire, it is dependant on the batteries for display. Change out batteries and see what happens. Obviously with no display, your system won't work. If this doesn't solve your problem, replace the thermostat.
Apr 26, 2011 | White Rodgers White-Rodgers 1F85RF-275...
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Jun 21, 2009 | Jensen's VM9312 Car DVD Player
Pc to tv problem
The most common problem is that the tv dont understand the s-video signal. You can try to change the signal input on the tv to s-video, but it will only work if your tv support's it. I have a s-video to scart but I dont get any collours because my tv can't understand the signal. My solution tip for you are: Get a tv that you are shure can understand the s-video signal.
Mar 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Matsui m19lid618
A regular TV will not display a CCTV camera, because the CCTV outputs a 1 Volt peak-to-peak RF signal. A TV uses a broadcast signal, it is different. However, if the TV has a yellow "video in" jack on the back of the set, this will display the camera, as the yellow video in will process and display the CCTV signal on the TV. Let me know if this does not work.
steven.burman@commandtechnologyassociates.com
Dec 05, 2008 | Home Security
Tb100mw9 converter did not work.
You need the audio/video cables and to put your tv on a channel with no signal (3 or 4).
Nov 21, 2008 | Sony RMT-V202 Remote Control
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw Logo
629 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
