Question about Whirlpool LSR8433K Top Load Washer
Whirlpool direct drive top loader will not spin
My whirlpool direct drive top loader will not spin. Pumps out water ok but will not spin. Makes what sounds like to me like a humming noise when it should spin. Is there a test for isolating problem? How much trouble to remove transmission? Would appreciate any advice on this problem.
  • Anonymous Mar 13, 2014
    My samsung vrt top loader will not spin or pump
    President:
  • 1,136 Answers
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
Posted on May 30, 2009
I have a kenmore heavy duty, series 70,# 82872120.. It makes a humming noise and will not complete the rinse cycle or the spin cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82872120
If it goes through the agitate cycle, the motor and transmission are probably OK.
If it goes through the initial drain / spin cycles after the first agitate cycle, the Lid Switch is also OK.
The humming could likely be the timer motor. Try to manually move the timer to the rinse cycle. If the washer responds, the problem points to the timer itself.
See the sub component section on the Sears site for the Console.
The "Alt" part numbers are Whirlpool parts that can likely be purchased from a variety of on line or local parts stores.
Sep 26, 2009 | Kenmore Washing Machines
Will not agitate
Replace the direct drive coupling. Directions are in the attached video.
Apr 03, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR8433K Top Load Washer Logo
322 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
