Question about Matsonic MS-8188E Motherboard
5.25" floppy I have just fitted a 5.25" Shugart 465 floppy drive in my computer and windows xp detects it but when i put a disk in it cant open it when i go into the bios it is set as a 5.25" 1.2mb drive when I think it is a low density drive is there any way to fix this Thanks
  • aaronchidgey Jun 01, 2009
    I tried this but it dosen't have that option
    Brigadier General:
  • 10,406 Answers
Go into the BIOS SETUP, and change it from '1.2MB' to '320KB',
then 'save' the updated settings.
Posted on May 31, 2009
Acer Power F5, Set up did not find any hard disk drives installed on your computer,
Have you checked on the BIOS/CMOS Setup if the SATA is enabled? It it does not work try changing your sata cable with a good one... Good Luck.
Apr 29, 2012 | Acer Power F5 PC Desktop
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
Floppy disk drive not detected.
It sounds as if you have a registry error. try to go to device manager and uninstall the drive. Turn your computer off and restart and see if Windows detects it automatically
Feb 04, 2010 | Microsoft Windows XP Professional
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Windows xp setup does not detect hard drive
You need to use the RAID/ATA floppy disk that was provided with your motherboard. It was supplied either on the cd or on seperate floppies.
When you have the disk in the floppy drive you press F6 when it asks at the very beginning of loading files in the windows setup.
When the setup asks load the RAID/ATA drivers and when you go to install your hard disk will be detected. You will have to get a floppy drive and plug it up if you don't already have one. There is a way to build a windows setup cd which includes the ata/raid drivers but it's often easier to just get a floppy drive.
May 08, 2009 | Microsoft Office Professional 2007 Full...
Troubleshooting Floppy Disk Drive Problems in Windowxp
try using the floppy on another computer, if you have the same problem then the floppy is bad, if it works on another computer then your floppy drive might be bad, if you built the computer, try using another cable for the floppy drive, i ran into problems like that when i put bad cables in
Dec 04, 2008 | Microsoft Windows XP Professional
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Matsonic MS-8188E Motherboard Logo
Top Matsonic Computers & Internet Experts
David
David
Alan Hohenbrink
Alan Hohenbrink
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
