Hi folks i just bought acer 1160 model projector and want to connect to my sky box to it for best picture quality my projector has only vga,svideo inputs only . i tried scart to vga cable but msg comes on screen as connection not compatible ,any solution pls hi, ive just had sky fitted to my optoma hd65 and cant get any picture colouur just black and white,ive tried everything i can think of?thanks
SOURCE: Optoma EP716 source detection
I had the same and it turn out to be that my VGA cable was broken
Chyneeman
SOURCE: how to connect projector to sky plus box using RGB
i have same problem as above can you advise please
SOURCE: My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
SOURCE: need to somehow hook up speakers to hd65 optoma.
HI there the normal way to sort this problem in most installations is to run active speakers straight from the sound card on the pc /laptop that is running your presentation and nothing to do with the projector
skytec make a good range of quality active speaker available on the net
SOURCE: new beamer optoma hd65,message: no source found
adjust the resolution to match. also, make sure the monitor port is activated.
