Question about Sony Playstation 3 (PS3) Console
Ps3 error code 80711008 and wpa
Im trying to gain access to http : ://192.168.1.254 via my ps3 browser when i log in it gives me error code 80711008 and my laptop isnt working and i need to obtain my ip address and wpa to set my connection on my ps3 to whireless can anyone help ?!
    Problem Solver:
  • 5 Answers
OK for your WPA you can check the security key by accessing the router http://192.168.1.1 .. password is by default "admin" and username is blank...go to the "wireless" tab and check the ssid...under "wireless security" check the security key...if you have "wep" check the numbers in "key 1"....
now make sure that you connect to your own ssid and type the correct key...
and you are right , you need wlan to connect to the internet wirelessly...however , first make sure that you have internet working through the router..if not you will have to configure the router and for that you a computer connected to the router...
As for your IP address simple use this site http://www.ip-adress.com/ should be everything you need
Posted on Jun 01, 2009
How to change my password
If by "password" you mean the access code one uses to gain access to your wireless network, first you must log into the router. This is usually done by opening a browser (any will do) and typing "http://192.168.0.1/" into the address bar. You should get a log in screen; the default administrator account is usually "Administrator" or "Admin" and the default password is usually blank. From there, follow the menu items for either "wireless" or "security" until you find the WPA2-PSK Passphrase, WPA Password, (or something similar) and enter the new password you would like to use. WARNING: If you do this from a wireless device, you will lose connectivity as soon as you change the password because the router will reset and the new password will become active. It's always best to do this sort of thing from a computer physically connected to the router.
Nov 22, 2013 | Computers & Internet
Tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
on Feb 21, 2011 | Sony Playstation 3 (PS3) Console
I cant sign in on playstation network it is error code 80710092 what is going on
I tried logging in from the Playstation store and it worked that way. I had the same problem at first for about 10 minutes.
May 29, 2011 | Sony Playstation 3 (PS3) Console
I am not able to access my yahoo account, showing error code#1, please advise.
1. Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2. If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do
[Start] > [Run] > cmd > ipconfig
{{write down the IP address, then disconnect from the Internet with}}
ipconfig /release
{{wait a few minutes and then reconnect with}}
ipconfig / renew
{{compare the new IP address to the old to make sure your IP address changed, then try again}}
If you are an office user, try someone else's PC which will have a different IP address.
3. Log into Yahoo through a different country's server. I.e. if you usually log into Yahoo via http://login.yahoo.com/ or http://mail.yahoo.com/ then try http://login.korea.yahoo.com/ or http://nz.yahoo.com/
4. Access your Yahoo mailbox via http://wap.oa.yahoo.com/
5. Use a different browser. Use Firefox (free download from mozilla.com) if you normally use IE or Safari.
6. If you have a web accelerator (mostly an affliction of dial-up users) then try turning it off.
7. If you use a proxy server (mostly a corporate user thing) then try turning it off.
Nov 20, 2010 | Yahoo Mail
I keep getting Error Code 1
1) Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2) If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do
ipconfig /release
ipconfig / renew
3) Log into Yahoo through a different country's server. I.e. if you usually log into Yahoo via http://login.yahoo.com/ or http://mail.yahoo.com/ then tryhttp://login.korea.yahoo.com/ or http://nz.yahoo.com/
4). Access your Yahoo mailbox via http://wap.oa.yahoo.com/
5) Use a different browser. Use Firefox (free download from mozilla.com) if you normally use IE or Safari.
6) If you have a web accelerator (mostly an affliction of dial-up users) then try turning it off.
7) If you use a proxy server (mostly a corporate user thing) then try turning it off.
Jul 05, 2010 | Yahoo Mail
How to restrict usage of my internet via belkin 54 g router gateway by my neighbours when they see my wireless connection,I mean how do I create a user name and a password where do i go step by step to do...
Follow directions in the manual to access the setup program built in to the router. This is usually done by using your web browser and going to an address like http://192.168.1.1 or whatever adress works with your router. After logging to the router, complete the Wireless setup. I prefer the WPA=PSK[TKIP] as it is more user-friendly on passwords. After this process is complete, you will need to use wnatever passphrase you choose to gain access to your router. You will need login info from your Owners Manual to get to the router's Admin program.
May 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I have a 180 gb ps3 & i am trying to hook internet up to it using my wireless router, it's picking up fine but it keeps asking for a WPA key & i have no idea what that is?
wpa key is the security code on the router .........whoever set the router up will be able to give you that code (parents/roomate or whatever) if it is your own router you can log into the router and turn the security off or reset the WPA key ....if you have any other questions let me know
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Cant connect my ps3 to wireless internet
you can auto config your network settings on the ps3, make sure you see your wiresless network, if you dont your router is not broadcasting its ssid and you need to activate it by logging into your router from a pc ( in a browser go to "192.168.1.1", username is "admin" password ia "admin" or nothing, unless you set up otherwise)
If you dont remember your WEP/WPA code you can find it under "wireless" then "security" in the router once you have gained access as mentioned above.
If all of above is ok then check your IP on your ps3 in settings, network status (i think havent done it in a while) make note of it and go back to the router as mentioned above. click applications and gaming then dmz, enable dmz and type in the ps3 ip, save settings and perform a 30 second reboot to the router (unplug it for 30 seconds) all should be good!
one last note if you have configured everything and you cant connect or it takes ages to do anything, you may need to reposition the router, mine is on the otherside of the room and is working great =p
Feb 19, 2009 | Linksys Wireless-G WRT54G Router
PS3 WIRELESS CONNECTION
This code (80711008) is not reffered error code list
Try first to establish a success connection at a nearer distance. Your signal strength might not be strong enough to have a lasting connection
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,935 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
