Question about MSI K9N GM2-FID (7252030K9NGM2FID) Motherboard
Doesn´t start Hello! My comp. by the motherboard suddenly doesn´t start. All HW is OK, but most of trying time BIOS doesn´t upload. When rarely yes, the W7 (my legal W XP completely destroyed probably by a virus, as well as the BIOS I think, but I´m not a specialist, only an usuall user) makes a crazy start. Now I´m writting from the comp., but I never know, if my comp starts next time... Please, give me a text guide, how to reinstall a new version of BIOS and be so kind and send me the BIOS to my e-mail ivo.valek@centrum.cz. Thanks a lot!
  • 600 Answers
Have you tried "Last known good configuration"?
Posted on May 30, 2009
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
Nov 03, 2009 | EliteGroup P6STP-FL Motherboard
Memory clock running @ 166mhz and cpu temp from 111-145 degrees I have to f1 every time I boot up?
Hello!
I have just a few information abuot you problem.
I don´t know what degrees ( I think is F, because if degrees of Celsius you have big trouble).
If the temperature is normal, in most case you need to change a battery at your motherboard, because they is empty and bios lose information.
You also can have problem with another parts like CD or DVD rom, or if battery OK with some information in bios.
I hope that will be useful.
Nov 03, 2009 | Soyo KT400 Dragon Ultra Motherboard
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
When i power on the hp 530s pc it goes straight to power-on password and cant hit F1, F10, F12, or delete to get into bios and i forgot my password is there anyway to disable the password from a jumper on...
Hello!
You have jumper at the motherboard, or at some comp. more switch, or you can take batery from motherboard about 1 - 5 min. When you cler cmos, password can´t be a problem.
Oct 30, 2009 | HP DS530S (PB373US) PC Desktop
Motherboard ga945pl-ds3, when I turn off power suply, I can´t start computer (culer works, I have power, but procesor don´t want to start), but after that computers works. I must reset bios (that...
PSU could also be playing up and not giving correct voltage to motherboard - check outgoing voltage from PSU with voltmeter and check product standards for that model... If ok then it could be the motherboard itself - all it takes is a capacitor or transistor/logic gate(switch) and it will start behaving unusual...
May 05, 2017 | Gigabyte Computers & Internet
Computer simply don´t open, mother board doesn´t too
TRY ANOTHER RAM IF THIS DOES NOT WORKS
TRY RESETTING THE BIOS CONFIGURATION FROM THE JUMPER ON THE MOTHERBOARD
OR ELSE THE MOTHERBOARD NEEDS A REPAIR IF IT FALLS UNDER WARRANTY PERIOD
TAKE IT TO THE SERVICE CENTER OR ELSE BUYING A NEW ONE IS THE BETTER OPTION
Jul 08, 2009 | Computers & Internet
Prog not starting up
hello
its is a quite coomon problem,and the cause can be both the hdd and the windows itself.
if you said that the hdd is ok,try to install a new version of windows
for me iit worked almost all the time.
but to be sure first check the cable settings in the computer,all the connection,check the ramm dims and the bios setiings.if all seem to be normal,try a fres windows.it will fix your problems.120%:)
the registers of your windows are damaged and thats why you need a new version..
bye bye
Feb 06, 2008 | Intel Motherboard
MSI K9N GM2-FID (7252030K9NGM2FID) Motherboard Logo
103 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
