Question about HP Compaq Evo n610c Notebook
Compaq laptop Evo N410c Battery charging
I bought this laptop second hand and was told tht the battery needed replacing.   Bought a new battery and fitted it but there seems to be a charging problem combined with  starting problem.  On plugging into the mains the battery warning light often does not come on to indicate that the machine is ready to be powered up   After unplugging and replugging the light comes on after five seconds and the machine is ready to use.   The light indicates that the machine is charging but at no time can I get a full battery.  The best I can get is 12% and that figure fluctuates down to 9%.   At no time will the mnachine fire up just on the battery.   Potential the battery charger working (properly),  do I have a duff battery?   Can you help?
  • glenfarg1 Oct 25, 2007
    Did what you said.   The AC adapter is O.K.   Tha battery will not charge and the machine will not start on battery.   I checked the drivers and sought an update from Microsoft but it is their latest driver.   The HP website was checked but I could see no drivers for "HP battery check"   I went through all the downloads looking for sp32299.exe but could not find it.   Can you tell me where to get this exe file?
  • 3 Answers
First remove the battery and run only on the adapter... If it works fine then there is no problem with adapter...... Charge the battery continuously for 4 hours without seeing the percentage of charging and remove the adapter..... If the laptop runs on battery for 45 mins then it might be the problem with drivers..... Go to device manager and reinstall the drivers if it is less than 45 mins.... Reinstall the drivers either ways...... If still the problem persists.... Go to and and select software and driver downloads and give the product number.... select the OS... Select HP battery check.... Download the file (sp32299.exe) and click save.... Save file onto the desktop and close the site..... Run the exe file.... If it passes the battery is fine... If fails replace the battery....
The steps might be longer..... But i can assure that it will work
Posted on Oct 22, 2007
  • pavani bharadwaj Oct 31, 2007
    if you are using vista... go to hp totalcare... click on battery health check... the test will run....
Replacing bios battery in evo n410c laptop
Dissemble the laptop and find bios battery. It is smaller than desktop bios battery. Usually covered by plastic wrap. Remove it and replace with new one. Observe the polarity of battery carefully.
Jan 25, 2011 | Compaq Evo N410C Notebook
How to get my laptop to charge.
If you battery is totally dead you need a replacement unit - remove the battery power the unit up using external power pack then refitt the battery - if it won't charge the battery is dead. get a new battery
May 19, 2010 | HP Compaq Evo n610c Notebook
When I turn laptop on it goes to sorry for
Try formatting a new version of Windows into the system if you don't have much to loose on it but you try this
switch off the system
remove the battery
press and hold the power button for 30 seconds
insert the battery without releasing the power button or plug directly to power source if putting the battery back will be hard for you
Then release the button and switch on the system
or google "how to clear black screen"
Jul 29, 2017 | Compaq Evo N410C Notebook
Time and date wont store
A battery would fix this but it is the battery on the motherboard that you need. How old is this computer?
Dec 30, 2008 | HP Compaq Evo Notebook N600c
Charging problem
Sounds like a defective battery to me ...or perhaps a faulty charging system. Least expensive solution is run on no battery, AC only. Second cheapest is replace the battery. Third option (note I didn't mention "cheap") is to replace the motherboard. Last option is to replace the laptop (might be cheaper than fixing the laptop, if you factor in age, warranty, time, effort and headache involved.
Hope this helps - remember to rate :)
Oct 01, 2008 | HP Compaq Evo Notebook N600c
Compaq EVO N400C PC Notebook Problem brought new battery! fully charged all night! turn laptop on within one second the thing turns off! AC works fine! new battery! old laptop! what can i do, please help?
your laptop should function even without a battery. Remove the battery you just bought and see if only with AC adapter, would your laptop turn on?
If not, then try removing the memory and see using a pencil eraser, clean the contacts of the memory and see if you can power your laptop with only ac
Apr 05, 2008 | Compaq Evo N400C Notebook
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When you first receive your laptop battery charge it fully for at least 6-8 hours and then discharge the battery fully by using your laptop unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If you regularly use your Compaq Evo N400c Laptop on mains power for extended periods, removing the battery from your Laptop during these periods will extend the usable life of your laptop battery.
Compaq evo N410c sound and video play too fast
I bought a used Compaq evo N410c and had the same problem.  I went to HP's website and downloaded the ADI Soundmax Audio Drivers and both video/sound are working fine.  The drivers installed without any problems, I was not prompted to insert any disks.  nicole79, sounds like you may have downloaded the wrong drivers.
Mar 28, 2008 | Compaq Evo N410C Notebook
Downloads play too fast
Oct 15, 2007 | Computers & Internet
The below was copyed from an earlier post of mine, it applies to you. It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Good Luck Follow the below link for a step by step on how to build your own battery
Sep 19, 2007 | HP Compaq Evo Notebook N410c
HP Compaq Evo n610c Notebook Logo
200 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
