Question about Technics SL-BD22 Turntable
Technics Turntable Auto-return problem - please help !
I just bought a second-hand Technics SL-BD22 semi-automatic turntable. It plays fine, sound quality is great, but I'm having a *really* annoying problem....
The auto-return happens way too soon. I haven't actually managed to lsiten to an entire song yet, as it always cuts out about 3/4 through... Maybe this has something to do with the fact that I like listening to drum'n'bass, which usually has long 6-7 minute songs, maybe the turntable is set to return after 5 because most songs aren't that long, but then, that wouldn't make sense if I was listening to a full album; and a 7" would cut out only halfway through...
Now, I might have only just gotten a turntable, but I'm not *that* stupid - I *did* read the instruction manual, and there's a little screw for adjusting the auto-return. One way makes it cut out even sooner, the other way makes it cut out later. I turned it all the way both sides (just to see) and in both cases it still cuts out way too soon...
this is extremely annoying, as I have only just gotten my turntable and was hoping to listen to all my records, but they all cut out half way... is there any way to manually adjust the auto-return so it cuts out later; or even better - to disable it, making it a sort-of manual turntable ?
Thanks a lot, I really appreciate all and any help I can get here :)
Dan
P.S. if nothing else works, I doubt very luch it's a good idea, but how about bending the tonearm ? I don't like that idea at all, and I don't want to break anything but I'm wondering if it's the only way...
  • 4 more comments
  • methoddan May 30, 2009
    Hello Charlie,
    don't worry, I'm not that kind of person. I'd really like to get this problem sorted, as it's such a shame such a silly thing is ruining all the fun (vinyl sounds much better than any other audio format I've ever heard... and it's only the first day I've used my turntable), any help - even if it doesn't work - is really appreciated, so I'll be sure to rate you and leave feedback, just for the effort.
    I've been told by enough people that beding the arm is the worst idea possible, so that's not going to happen.
    I find it hard to clarify the problem further; as that's just it - the auto-return on my table kicks in too early.
    I have tried adjusting it with the auto-return adjuster screw, and after a short experiment listening to the same vinyl twice, once with the screw set to minimum (auto-stop is earlier) and the second time with it set to maximum (auto-return is later) , it stopped at the same point.
    The screw seems quite loose (by that I mean easy to turn, not tight) , and only goes 1 half-turn between min and max; not sure if that's normal or not.
    I'm wondering if something has slipped or disconnected on the inside, as whatever I do with the adjuster screw, it still cuts out early (after about 5-6 minutes.... that's annoying with 7 minute songs all the time)
    It's a shame there's no easy "on/off" button for the auto-stop, I'm starting to wonder if I should have bought a manual turntable, but it's a lot of bother to sell it and buy another one, so I'm hopnig there's a way to adjust the auto-return so it happens later - like, when the song's finished and not halfway through.
    I'm new to turntables; I can use them, and I usually learn quick with things, but I have no idea about the insides and so don't wnt to mess around too much if it might damage it. I don't know exactly how the auto-return screw works, but maybe there's something on the inside I could adjust manually, as the screw doesn't seem to be doing anything.
    I've doanloaded a service manual PDF file, which gives disaassebmly instructions and an exploded view; but doesn't help with my problem.
    I hae no idea, but is this a case of opening it up and turnibng whatever the screw doesn't seem to be turning, or re-aligning some cogs (if there are any) so the auto-return happens later ?
    A way to disable the auto-return is just as good; I'm sure I can manage to put the arm myself back when the record's over.
    Again, any help is greatly appreciated; and if I can give any further details just tell me what you need to know.
    Thanks again,
    Dan
    Hi Charlie,
    that would make sense, I have a feeling there's some way to set this from the inside.
    Unfortunately, I can't see much through the tiny hole, and it seems it opens from underneath, too so I doubt I'll be able to see it working whilst open, unfortunately.
    the service manual came from the Vinyl Engine.
    I can send it to you, if that's any help - it might be easier through direct e-mail (mine is bleriott@aol.com) ?
    I haven't tried anything yet, as I don't want to mess around too much without having much of an idea of what to fiddle with, as I don't want to damage anything.
    Dan
    Success !!!!
    It's done - all that was needed was for a part to be removed from the auto-stop mechanism.
    I didn't even need to open up the table - I removed the platter and mat because I was going to open it; but then underneath where the platter was I could see the whole mechanism, and work it out from there.
    I needed to remove one thin metal rod joining the arm to a plastic 'trigger' on the inside; now it plays record until the end; and is sort-of still semi-automatic as the 'stop' button still works, and it brings the arm back to the beginning, all I need to do is press the button when the song's over - a million times less annoying than having it cut out halfway through !
    Thanks again !!!
    Dan
    Happy you could help out, too !
    No problem leaving feedback, it's the least I can do to say thanks - I certainyl didn't expect to get ann answer so soon, and to have everything fixed within a day; and for it to be something so easy to do , thanks again !
    Dan
  • Samuel Charles Spriggs May 11, 2010
    Dan,
    I think this is the key:
    " maybe there's something on the inside I could adjust manually, as the screw doesn't seem to be doing anything."
    The screw adjustment on the tone arm causes a mechanism to trip ("inside" the unit). There is some problem with that mechanism is my guess. So, I think it's remove the turntable from its base and place it somewhere which will allow you to watch this mechanism operate.
    If you could tell me how to get to the pdf file you found, that would be very helpful.
    thanks...
    Charlie
    I would like to help with this. I'm reluctant because I fear I willI spend a lot of time on it and you will stop responding giving no feedback or rating -- this is true with 80% of the posts fixya experts enter.
    If you are interested in working with me on this, I'll do what I can to help get this thing working right. It may take a while. I don't have any simple quick solution. I have worked on many turntables -- they are the most amazingly complex mechanical devices I've ever seen.
    Charlie
    President:
  • 1,489 Answers
Great!! You're Happy, I'm Happy.
Now there's some kind of rating procedure on this screen. If you could rate my asistance, I'd appreciate it, Dan.
thanks...
Charlie
Posted on May 30, 2009
2 Suggested Answers
STYLUSCITY
  • 271 Answers
SOURCE: Trying to track down a tonearm plug in connector and stylus for an SL-BD22. Is it possible to get the connector separately? Can you recommend the best place to get them?
Hi, Is it the headshell you want like this?
If so I have 1 in stock $39.90 USD. I also have an original Technics EPC 24 P mount cartridge with stylus which were fitted to SLBD series $49,90 USD. Cheers John. styluscity@gmail.com
Posted on Nov 11, 2011
Technics FG Servo SL-22 auto-return problem!
Find a way to hang the unit, keeping it level. I use 4 coat hangers, cut off and bent to a hook at the bottom. Put a safety string , wire or clip on one of them in case it gets bumped. Using your hand, turn the turntable and let it go through it's cycle. You will be able to see where and when thinks happen. Some have notches and some are friction fit. As long as you don't force anything, you should be able to realign the timing of the gears.
Dec 18, 2012 | Technics SL-BD22 Turntable
How do I remove the platter on a sl-bd22 Technics turntable?
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
Jul 12, 2010 | Technics SL-BD22 Turntable
I need a replacement lid/dust cover for my turntable technics SL BD22; Can I get one and from where? and the price aswell please
There are 2 complete turntables up for auction on Ebay. One is at 4.99, and the other is at 9.99. Just do a search.
Apr 28, 2010 | Technics SL-BD22 Turntable
I just purchased a Technics SL-BD22 turntable and it came without the ground wire. Is there anywhere I can purchase this proprietary part?
just get any small speaker wire and use that as your ground , attach that to the reciever you are using
Jan 16, 2010 | Technics SL-BD22 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Turntable grinds to a halt.
The Technics SL-BD22 is a belt driven turntable. It is most likely possible that the belt wore off, wore down, or could have spun off. The platter should have 2 holes in it. One of them should alow you to see, and replace the belt. YOu can lift the platter off the turntable via those two holes. MAKE SURE IT IS TURNED OFF AND UNPLUGGED......
You can find a replacement @
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
And the part should come with instructions. Those guys are very thorough.
Keep me posted.
Nov 05, 2007 | Technics SL-BD22 Turntable
Technics SL-BD22 Turntable Logo
949 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
