Question about LG LSC121PMA Split System Air Conditioner
Hi i have a LG s246gc ac but its not working properly since i sett the tempreature at 18 but it always shows "out door" the weather out side is horrible so my room tempreature never was less than 30!!!! i tride so hard to fix it but i dont know what happend to it???
  • 45 Answers
Call a lg tech to come and have a look.its ment things that can cause that fault.
Posted on Jun 09, 2009
My lg washing machine just make a beeep sound then show a error de
de error mean door error. For fixing this you can try to reset using the instruction from lg site (http://www.lg.com/us/support/product-help/CT00000305-20150140270078-others).
If not work, maybe de switch is bad or the door is not closing properly.
Jun 10, 2017 | LG Washing Machines
Kia sportage 2008 v6,I've a problem with AC,In hot weather after 30 mins drive loose conditioned air and hot air start blowing although after switching engine off for may be 20 mins; AC start working
Bad blend door actuator is your cause. You need to disconnect the actuator from the blend door and manually check the blend door. One side of the door switches the heat and one draws air from the ac evaporator.
Jun 06, 2016 | Kia Cars & Trucks
How do I fit weather shields to a Suzuki swift
no year, so cant help. 2010?
but you can read the FSM any time, on USA cars, (this is USA site)
weather, you mean the side door seals.? what? name a place exatly on car or show a photo, or tell what leaks.....??????
usa cars are covered here. 100% so...
FSM (real)
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
we are USA forum(calif)
Feb 01, 2015 | Suzuki Swift Cars & Trucks
Cobre 18 wxstII
Check and be certain you are not on the weather band. if you are you can not transmit and if you are not set to the proper weather station you will hear nothing. Sound like your problem.
Apr 12, 2014 | Cobra Radio Communications
Ac intermittently quits working, just replaced condenser, put dye in system at mechanics- no leaks
Have an AC repair shop hook up a set of AC pressure gauges while this is happening to see what is going on. You could have a defective AC compressor or a low refrigerant charge in the system. And as to the hot weather causing it to act up that would be normal, the AC would cool fine the cooler the outside air is, problems like worn out compressors and low system refrigerant charge levels would only show there ugly head in hot weather conditions. Also make sure the cooling fans fo rthe AC and engine are working properly. Good luck with this.
Jul 11, 2012 | Cars & Trucks
I had a 53 fault on hitachi split ac system and after powering the condenser off and back on system now showing a p7 fault. Is this a refrigerant problem? Model no. Ras-6hrne
I think you should check your compressor manually . And then check the tempreature on discharge point of your compressor if tempreature increases then there is no problem of gas .
Nov 02, 2010 | Heating & Cooling
My nokia n73 is not working properly means always
try to format your cell
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Sep 29, 2009 | Nokia N73 Cellular Phone
No lights work after installer removed door
hi i would look at the hinge area where door was removed, theres electrcal plug there and if he,s not connected it properly then lights dont work.. funky
Jun 27, 2007 | LG (LSC21935) Side by Side Refrigerator
Heating & Cooling Logo
180 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
