Yamaha rx-v565 hok up
GOOD MORNING
I HOPE I CAN EXPLAIN THIS OK YOU SEE I AM A CARPENTER AND DON''T KNOW A LOT ABOUT ELECTRONICS
I JUST PURCHASED A YAMAHA RX-V565 REVIEVER
I AM CONNECTING TO DIRECT TV THE YAMAHA HAS ONE HMDI JACK FOR THE MAIN SORCE AND FOUR TO CONNECT TO OTHER COMPONENTS
I WOULD THINK YOU WOULD HOOK THE DIRECT TV BOX TO THE ONE HDMI TO GIVE A SIGNAL TO THE OTHER 4 HDMI JACKS
BUT THIS DOSN'T WORK I HAVE TO CONNECT THE TV TO THE MAIN HDMI HOOK UP ON THE RECIEVER THEN GO TO FROM ONE OF THE OUT JACKS TO DIRECT TV IT WORKS BUT IS IT RIGHT
THANKS
CHARLES WYATT
  • 20 Answers
SOURCE: No sound at all
The jumpers are there to connect the preamp section to the power amp section and are required for the receiver to opperate properly. Make sure the receiver is set to the proper input, in this case: CD. If there are A/B speaker connections, be sure the receiver is set to match the connectors you're using. If there is still no sound, profesional service will be required.
Posted on Oct 10, 2007
djnick989
  • 1067 Answers
SOURCE: Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Posted on Jan 23, 2008
SOURCE: variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Posted on Feb 26, 2008
SOURCE: yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Posted on Jun 12, 2008
  • 4234 Answers
SOURCE: Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Posted on Feb 25, 2009
Yamaha rx-v565 wont turn on. Not "Click Sound" when Press On Button
It sounds like the output ic and or transistors have blown and need replacing. Did you short the speakers or cables?
Dec 01, 2016 | Yamaha Rx-v565 Receiver
I bought Yamaha RX V565 4yrs ago, then after 2 years, may receiver always shut off 5 minutes everytime I open. What is the problem or reason of shutting down my receiver? Thank you
press and hold both the "DIRECT" and "TONE CONTROL" buttons and press power and see what it says on the display. This will give us some idea of what is causing the receiver to turn off.
Mar 30, 2015 | Yamaha Rx-v565 Receiver
My Yamaha RXV -2500 started switching audio signals from one componet to another! Example - Sat/Cab sound coming out of the Wii and Wii coming out of the Sat/Cab. I have not touched anything and this...
You need to go into the "GUI" menu and re-assign the audio inputs to the correct source. The manual will walk you thru it as well. If you still need further help, post a comment or reply and I can help with further detail. Hope this helps.
May 31, 2011 | Yamaha Rx-v565 Receiver
How do I reset my Yamaha RX-V565 Home Theatre Receiver?
Unplug it for 10 min and plug it back in. If you need more specific help with an issue with this receiver, post a comment and I can help you further. Hope this helps.
Feb 28, 2010 | Yamaha Rx-v565 Receiver
My yamaha rx-v565 wont turn my sub woofer on.It detects that it is there during setup but doesnt turn it on during music or movies.
make sure the switch on your sub is on, and also if there are no "sub signals" then it wont kick on tru listening/watching somthing with alot more bass to see if it kicks on
Dec 17, 2009 | Yamaha Rx-v565 Receiver
Where can i buy a replacment microphone for my yamaha RXV1500 home cinema?
call yamaha, they will send one. check with someone who installs. they usually have extras
Dec 07, 2009 | Yamaha Rx-v565 Receiver
We have a Yamaha RX -V565 and after listening to music the entire system shuts down. We turn it back on and it works for a while? We installed new speakers with new 16 gauge speaker wire. Anybody know...
chances are youve got a short at the rear of the receiver. look for frayed speaker wires touching the chassis of the stereo. use a flashlight. it only takes one tiny hair of a wire to short it out
Nov 01, 2009 | Yamaha Rx-v565 Receiver
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Sep 26, 2009 | Yamaha Rx-v565 Receiver
173 people viewed this question
 Grubhead
Grubhead
