Question about Motorola Talkabout T6210 (14 Channels) 2-Way Radio
The working frequency range for talkabout T6210
More thanks !!!
  • Motorola Master
  • 1,654 Answers
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placementof your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see.
Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
Posted on May 30, 2009
Frequency range motorola t5000
http://shop.giantintl.com/Manuals.asp?offset=30
Sep 28, 2013 | Motorola TalkAbout T5000 2-Way Radio
Why is not possible to communicate from T5720 talkabout to T5422 talkabout?
The two radios share no frequencies in common. The T5720 has the US frequencies classified as FRS and GMRS, between 462-467 MHz. The T5422 has the UK frequencies classified as PMR and dPMR which are in the 446 MHz range.
A list of UK frequencies can be found in this forum: http://www.transmission1.co.uk/forum/viewtopic.php?f=4&t=23400
Best regards.
Oct 01, 2012 | Motorola Talkabout T5720 (7 Channels)...
I have a set of T4525s and another set of T4508 Can they communicate with each other?
Hi
Absolutely no because
MOTOROLA T4508  frequency range: 409.7500-409.9875MHz
MOTOROLA T4525s frequency range: 462.5625-462.7250MHz
Aug 30, 2010 | Motorola Talkabout T4500 (7 Channels)...
Are motorola talkabout t6210 and talkabout 200 compatable. I have the eavesdrop reducer turned off on the t6210 but the transmissions are garbled when recieved by the talkabout 200.
Yes, they should be compatible. You are correct in shutting off your eaves drop reducer. You might also check to see you have your interference eliminator code set to zero (off). We have been unable to find a good online source for a user guide for the T200, but if memory serves, they do not have "code". Here is a link to the very similar T280 guide: http://www.giantintl.com/ContentManage/manuals/Moto/T280_User_Manual.pdf
And here is a link to the T6210 user guide http://www.giantintl.com/ContentManage/manuals/Moto/T6200_User_Manual_E.pdf
Between the two radios there should be 14 frequencies in common. If you continue to have difficulties you might check to see if your batteries are good and/or fully charged. This also can interfere with good communications.
Best regards.
Aug 22, 2010 | Motorola Talkabout T6210 (14 Channels)...
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
How can i change u.s. motorola radio frequency to u.k. frequencie
Sorry, but the freq range of these radios cannot be reprogrammed.
Bill B
Mar 19, 2010 | Motorola Talkabout T5500 (7 Channels)...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
One of the T6210 radio will send and receive. The other will send but not receive
The one which will not receive possibly has a different interference eliminator code from the first unit. Check your programming. Your freq., code and Qt filter (if any) must match identically. If everything matches and you still cannot receive, you have a bad radio.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T6200_User_Manual_E.pdf
Jul 02, 2009 | Motorola Talkabout T6210 (14 Channels)...
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T6210 (14 Channels) 2-Way Radio Logo
206 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
