Connect rear camera power lead "Red +12VDC" to back-up lamp circuit in trunk. Splice into back-up lamp wire near bulb. https://www.6ya.com/callphilipforhelp
These are on pins 5 and 6 of either tail light assembly. You can splice the backup wire to the wire on pin 5. For the ground, trace the wire from pin 6 to where it connects to the frame. Attach the camera ground to the frame there.
There may not be a wire in the dash, the connection depends on the shift lever's possition and usually a switch near the shift lever that turns the reverse lights on. If there is actually a reverse light on the dash, look for the wires to and from that light.
It's so simple. According to international colour code the +ve wire should be either red or yellow and the negative wire should be black or blue. you need to secure the camera power wires to the right wires of the rear lights and it's done. the image signal cable wires should then be connected to the LCD screen on your dashboard or a detachable one.
ASE Mechanic:
with out any schematics you can trace these wires down by finding the reverse lights, and disconnecting the bulb and installing a test light, and with a buddy put in reverse while you check to see which wire gets hot!!!!!!!!!!!!!!!!!
