Question about Dell OptiPlex GX270 PC Desktop
Usb ports are not working even after windows installation
I have a desktop of dell 270 i am facing a problem that no usb port is reconoising neither infront nor of back side i have reinstalled windows twice but the problem is same
    President:
  • 156 Answers
Hey Hi...
You need to install the CHIPSET DRIVERS. Just click on the link below for downloading and installing the chipset drivers and your USB PORTS will start working
CLICK HERE FOR THE DRIVERS FOR WINDOWS XP
CLICK HERE FOR THE DRIVERS FOR WINDOWS 2000
Reply to the post immediately if u need further assistance...
Do Rate This Solution...
Posted on May 30, 2009
Usb port aren't working
Ok these usually happens only because of the drivers not installed or if the right drivers are not installed, Go to device manager and check for USB controller and check for drivers, if missing check your motherboards model number and download the appropriate drivers from the actual brand website of your motherboard. should work now.
May 05, 2014 | Dell OptiPlex 960 MT PC Desktop
Usb wont work
check this things
1.make sure the minimum hardware and operating system requirements of the hardware to be installed are met.
2.just make sure the latest bios code is installed.
3.then make sure the usb is enabled in the BIOS. power on the system, press f1 to access the system configuration utility.click devices and i/o ports and then click usb.
5. make sure the usb controller and hub are listed in the device manager as will as any installed devices for the usb option.
6. then you can try the device in all available usb ports.if it works in other usb ports, the non working ports probably defective.
Nov 04, 2012 | Dell Inspiron 570 Desktop PC (I5707163PBK)
Front USB port on dell dimsion 3100 not working
Check all internal connections as they may be loose if not the USB controller has failed. I hope this helps.
Sep 04, 2012 | Dell Dimension 3100 PC Desktop
EMachines 270 rebooting whenever new USB inserted
sounds like you have a short circuit try a diffferant usb port or a usb extension
Feb 11, 2012 | eMachines Computers & Internet
Dell inspiron n4010 right side usb port not working what is the resolution
I also faced the same issue on my dell Inspiron.
The problem is that my USB driver got corrupted somehow and hence my laptop stopped detecting nay USB drive.
I found out that there is a driver that we need to re- install. But then again the problem is
Dell N4010 does not have drivers for Windows 8 :-(
So I needed to install it in compatibility mode.
I made a small article about this issue with snapshots.
http://www.placementyogi.com/articles/commonissues/Dell-Inspiron-N4010-Not-Detecting-USB-device-or-pen-drive-Solved
This is an external link outside dell forum, I am not sure If I am allowed to do so but I cant write all the steps here:
Sep 22, 2011 | Computers & Internet
My usb ports do not workon my dell dimension c521
1 rollback your drivers, 2 check device manager , Install origional that worked. Also windows updates for hardware drivers.
Apr 25, 2010 | Dell Dimension C521 PC Desktop
I have a dell computer I think its a 3100 and none of the three usb ports are working. Is there a way to have this fixed?
dear,
have you install the new windows..
is it you first try..
If you have installed the windows and the usb ports are not working, you need to install the drivers of the motherboard and can be got from this site..
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&SystemID=DIM_PNT_P4_3100&os=WW1&osl=en&catid=-1&impid=-1
you need to select your operating system and the other selection and can recieved the drivers..
if it was working fine and immeditely, it stopped working due to some reason then again do this step..
hope it will surely fix the issue...
By the way, if this method doesnt work, then you have check whether the usb ports are enable from the CMOS setup by pressing DEL of F key that if shows in startup to go in it..
goodluck dear....
Sep 03, 2009 | Dell Dimension 3100 PC Desktop
New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | Dell Computers & Internet
Dell Optiplex 745 series keyboard and mouse (both usb stop working after windows starts)
Could try going into windows safe mode and select basic shell. It may then allow you to reconfigure the hardware settings of your system. Presume you have tried another usb port and removed other usb connected devices if they are using same settings ?
Apr 02, 2017 | Dell PS2 keyboard 04N454
Dell OptiPlex GX270 PC Desktop Logo
247 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
