Question about Dell Inspiron 1525 Laptop
Battery is not charging in my acer aspire 5052anwxmi
Hi, when i plug the charger into charge the laptop detects that it is plugged in however it will not charge it. I have checked the battery status and it says it is healthy however it is not charged a single bit so it means i can not work on my laptop when it is not plugged in.
  • 159 Answers
Check connections and also try to get another battery and test for the same
Posted on May 30, 2009
  • Paul Ssebata
    Paul Ssebata May 30, 2009
    check connections and also try to get another battery and test for the same
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Acer Aspire 5552 won't power up, charge light flashes on and off
Remove the battery and plug in the Cord/charger, will it boot? If no, try another Cord/Charger with the EXACT same power specs. Replace battery if necessary.
Mar 02, 2013 | Acer Aspire 5552-3691-24271 Laptop
Power is plugged in , battery is plugged in not charging with 0% available
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
Acer aspire 5332 plugged in but not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm:
Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Oct 23, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Hello , I have acer aspire one 751, with win
OK, it sounds like the acer aspire one 751 has a bad battery that will need to be replaced. It is not taking a charge, so it is not detected even though it is connected to the laptop. The 'plugged in' message shows that the charger is connected and detected by the computer, but the battery is 'not charging' due to the bad cells.
Good luck on finding a replacement battery.
Dec 18, 2010 | Acer Computers & Internet
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
Nov 27, 2009 | Acer Aspire 3610 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Dell Inspiron 1525 Laptop Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
