Question about Logitech Z-340 Computer Speakers
Our logitech z-340 speakers are not working and there's no power?
How can we power our logitech z-340 speakers?
  • 77 Answers
Plug the satellites into the subwoofer, plug the mini jack into your computer, plug it into a wall out, and turn it on.
Posted on May 30, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
Can not get subwoofer z-340 to work with i3 laptop. Speakers work, but not subwoofer
Ensure it is connected according to the manual and plugged into a wall outlet for power. The small speakers might work just being plugged into the computer but the subwoofer requires a much higher voltage to run.
Sep 28, 2013 | Logitech Z-340 Computer Speakers
Logitech Z-340. I need access to the volume pot in order to clean it. How can I take right speaker apart?
You need to pop off the grille on the front of the speaker. It's glued to the front. I just used a flat head screwdriver and worked it evenly around to slowly slide it off. Then, unscrew the 4 phillips screws to get to the inside.
Sep 03, 2010 | Logitech Z-340 Computer Speakers
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Logitech z-340 speakers
These speakers just plug into your sound output mini-jack. No "speaker" driver is required, just drivers for your sound card. I'll bet those are already installed.
Jan 19, 2009 | Logitech Z-340 Computer Speakers
Oct 27, 2008 | Logitech Z-340 Computer Speakers
Need wires for z-340
I just got one too. I guess I'll tear it apart and post the pinout. Also have a set of Altec Lansing satalites (ACS340) with the same connector (hmmmm, Z-340 -- ACS340... probably the same thing they just changed some pins)
I let you know!
Aug 24, 2008 | Logitech Z-340 Computer Speakers
Woofer Quit
Check the pin connection it is loose or the pins may be bent. Check Connection to sub hold it in tight if no pins are bent and see if the hum stops. Hope this Helps it is what was happening to my set>GOOD LUCK>If pins are bent straighten them>
Aug 13, 2008 | Logitech Z-340 Computer Speakers
Logitech Z340 Power speaker problem
yeah you can fix that one into your own. first thing that you do is get a multi-tester and put the two terminal the red one and the black into the tip of male plug of you wire. then set your multi tester into the ohms selector any ohm selector which found at the right side of the multi-tester. if the arm of multi-tester was moving it means OK... if not open the speaker carefully and reconnect the wire by using soldering iron & lead.
Nov 04, 2007 | Logitech Z-340 Computer Speakers
Ups and Downs with Logitech
yeah repair the volume switch, open the speaker carefully and pump out the lead which connected the switch and the board..
Oct 11, 2007 | Logitech Z-340 Computer Speakers
Logitech Z-340 Computer Speakers Logo
669 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
