Question about Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
When i boot my xbox up the tv will stay blank but i will hear the sounds that it usaully makes when it logs into my account. My XBOX will turn on and I will hear all the sound that it usually makes on the TV but the TV stays blank
  • jbsmith1002 May 31, 2009
    I Have tried a few different TVs and a different cable. Those were the first things I did. All results are the same, plenty of sound, absolutely no video
    Problem Solver:
  • 6 Answers
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
Posted on May 30, 2009
SOURCE: My xbox 360 wont show a picture but it has sound
when we experience a no video/display but with sound as if your logging in at your default blade, try to disconnect all the cables including the power cord and the audio video cable. (its the cable going from your console or xbox 360 to your tv). Before you plug it back try also to wipe the prongs or the metal part of the cables to ensure it has no debris or anything that would mess up the connection. If your using an HDTV make sure that the switch of your component cable is click on the hdtv settings. if it still not working for you, try to use a different cable and TV just to isolate the problem. If the issue still persist.. its the system that has a problem. Not exactly the hardware but it would definitely the prongs at the back of the console. So, bring it back to the retailer if its still in 30-days warranty or send for repair to its authorized service center.
Posted on Oct 15, 2007
  • 85 Answers
SOURCE: xbox 360
Check your AV cable if your tv is HD push the tab to HD if not set it to normal tv this should help you out. If that doesnt work i would try to borrow someones AV cable and try that.
Posted on Dec 11, 2007
  • 136 Answers
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
Posted on May 31, 2009
  • 1093 Answers
SOURCE: When i boot my xbox up the tv will stay blank but
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Posted on Jan 23, 2010
repairtech99
  • 767 Answers
This Problem is well known threw out most 360 repair shops.
The G.P.U. has lost the video feed due to thermal expansion
of the P.C. board. The remedy 9/10 is to have the G.P.U
re-flowed and then securely clamp to the heat sink. This
will yield the most durable repair . Cost will very 60.00-80.00
depending on warranty and track record of the shop.
If you need more info feel free to ask.
Rob
Posted on Mar 17, 2010
First thing to try, disconnect the AV cable and re connect.. Or if its the type with the switch that goes from HD to TV, flip it and see if it works
If none of that works, and your box is less than three years old, call Microsoft ( 1 800 MYXBOX ) and see what they suggest.
Mar 16, 2010 | Microsoft Xbox 360 Console
Jan 23, 2010 | Microsoft Xbox 360 Console
My xbox turns i hear the log in sounds but it stays blank.
try a different input on your TV or replace the AV cables
Aug 01, 2009 | Microsoft Xbox 360 Console
My xbox wont show picture only sound
just did one of those 1 hour ago
running great now
X clamp mod , it fixes so many problems.
Jun 30, 2009 | Microsoft Xbox 360 Console
May 31, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
try using a different input on the tv or a different tv. make sure that you used a totally different av cable. if this all fails then you have an internal hardware failure
Jun 20, 2008 | Video Game Consoles & Games
No picture...
I would try some of these troubleshooting steps;
  1. Make sure that the AV cables are 100% secure.
  2. Try an new AV cable.
  3. Try your console on a different TV.
  4. Call xbox customer support at 18004MYXBOX
May 31, 2008 | Microsoft Xbox 360 Console
Xbox 360
Nov 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
192 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
