Question about Saeco Royal Professional Espresso Machine
No coffee brewing with beans, but with coffee brewing with ground coffee.
Saeco Royal Cappuccino. The coffee hopper is full of coffee beans. On pressing the button for brewing coffee, the grinder starts, but after a minute, no coffee comes out, and the display says "empty coffee bean".
Make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
    Problem Solver:
  • 6 Answers
The grinder is set too close or fine to actually capture the beans and grind them. If you have adjusted the slider to the max coursness and it still doesn't work you can manual reset the tolerances. To do this empty the grinder of bean and remove the two screws holding the hopper down. Once this is off clean out any other beans and remove the rubber grommet cover with a X pattern that seals the hopper over the grinder. Now you can see an outer ring with lots of hole in it - take a white out pen and mark a line to mark its current position relative to the inner ring. Now roll upwards the coarseness lever to "pop" it off the outer ring. Wind the outer ring a quarter of turn anti clockwise to open the gap. This is why you make the mark. Replace the hopper and add some beans and give it a quick test. If it works ok then replace the coarseness selection lever in the middle position (5), rubber grommet and hopper and enjoy some coffee.
Posted on Aug 10, 2012
    President:
  • 1,618 Answers
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
Posted on May 31, 2009
The grinder grinds too long, then stops and then the bean refill light goes on, ---there are plenty of beans but no coffee being made. I think the grinder is not working somehow. Its a 5 year old Saeco...
The lever under the bean hopper is set to low. Push it all the way to the back.
There is a leverbehind the door in the middle top. Pull it to the minus and try again.
If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 05, 2011 | Saeco Royal Cappuccino Espresso Machine
The beans will grind but there is a bad clicking/knocking noise and coffee wont come out, water heats etc no error message
Hi
The dreaded clicking noise is usually the brew drive gears are broken. Usually caused by too much coffee in the brew unit that it can't compress ( 2 scoops of coffee). If you have ever done that, its broken but can be fixed.
Jan 03, 2011 | Saeco Royal Cappuccino Espresso Machine
Pucks in dregs drawer very wet
Hi
3 things can cause wet grounds.
1. You don't have enough coffee going into the brew unit. There is a lever on the right side behind the door at the top. Push it back towards the rear but not all the way. This will put more coffee in the brew unit and take up the air space so you will have less water.
2. Your grind is too coarse. Pull the lever below the bean hopper towards the front when it is grinding, to make the grinds smaller. Again less air space. Do this 1 number at a time so you dont make it too fine. Let each adjustment for 3 coffees before you make the next adjustment.
3. Your grinder has come apart and is grinding very coarse (French press). New grinder.
Dec 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
Grinder turns, but despite being full of beans, says "Cof. Beans Empty" - have cleaned thoroughly en used compressed air to rid any ground coffee that may have caused a blockage, managed to make 1 cup,...
Hi
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine above where the brew unit sat, there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back towards the center of the machine, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Oct 23, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco Royal not grinding... is it possible for the auger to wear out?
Hi
Yes the burrs can wear out. Have you tried to adjust the coarsness setting? Push the lever below the bean hopper all the way back and try it again. If that doesn't work there is a trap door above the brew unit inside. Open it and vacuum it out. Then try again.
Dec 18, 2009 | Saeco Royal Digital Plus Coffee...
Coffee beans don't grind even though there are beans in the hopper. Message: empty coffee beans. Grinder turns, but doesn't sound like the beans are going through.
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side of the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Nov 11, 2009 | Saeco Royal Professional Espresso Machine
Have saeco type sup 021 r it is saying it does not have coffe grounds but it is full tryed spreding around turning it off but still light is on needs coffee
Hi
Nov 09, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Royal=,beans do not appear to be grinding, machine whirs for 30 seconds then says add beans have tried 2 different types beans after cleaning bean hopper works first 2 coffees ok then stops
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Oct 02, 2009 | Saeco Royal Professional Espresso Machine
Saeco royal cappuccino coffee machine beans container empty fault
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Oct 30, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco Royal Professional Espresso Machine Logo
1,171 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
