Question about Dell Keyboard for Inspiron 1420, 1520, 1521, 1525, 1526
How to remove vista from 1525 laptop and install winxp
I found to trouble to remove vita from inspiron 1525 laptop ,
when computer is boot from xp cd , then when message comes hardisk drive not found or either unplug and press f3 to exit from installation.
Pls give me suitable suggestion to remove vista and install xp.
Thanks
  • 489 Answers
You have to get in Bios. you will find HDD section. it must be IDE/AHCI section. you need to do IDE if you want to install XP. XP doesnt regognize AHCI SATA drives.
Posted on May 30, 2009
I get a weird message when I try to boot up my computer. it is
Sounds like a failed windows update crashed the operating system. If Vista, boot to the Vista DVD, select the option to repair your computer and see if that will resolve, repeat running the repair process until it reports no errors.
If windows XP, boot to XP CD, press R at 1st prompt, run CHKDSK /R and see if that fixes the boot process.
If those fail, then you might have some luck with a repair of your Windows Installation from the Windows CD
Jan 11, 2010 | Dell Inspiron 1525 Notebook
When I start dell 1525 it say bad windows image.
Sounds like a corrupt windows install. Boot to the Diagnostics (Fn+Power button) and see if it indicates a hardware failure.
If diags pass, and running Vista, then Boot to Vista DVD and try repair my computer options. If XP, boot to XP CD, R for recovery console and run CHKDSK /R
Most likely you will need to either re-image the drive from the F8 menu for Vista or CTRL+F11 for XP, or if the hard drive is failing replace the hard drive.
Oct 19, 2009 | Dell Inspiron 1525 Notebook
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to...
If your laptop is still under warranty, installing WinXP will void the warranty. It's very tricky. I'd suggest getting another PC with Internet connection and search and download drivers as needed for your 1525. Good luck.
Jun 13, 2009 | Dell Inspiron 1525 Laptop
HOW TO INSTALL WINDOWS XP ON DELL LAPTOP
go into bios by pressing F2 - change the boot order so the cd / dvd drive is the first bootable device and use the installation / recovery disc you got with it and boot from the cd and re install or install windows xp.
If you do not have the cd then you either need to find it or contact dell and see if they have another one with a key ( which may be chargeable )
Apr 23, 2009 | Dell Inspiron 1525 Laptop Jet Black
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Download win xp
sorry u can't download windows XP u should purchase it and remove vista and install windows XP after installing u should download drivers for the dell laptop Inspiron 1525 of windows XP because vista is pre installed operating system including with drivers
Jul 29, 2008 | Microsoft Windows XP Professional With...
Installing xp on inspiron 1525
The reason why xp does not see the hard drive durin setup is the ahci option enabled in the bios. you need to change the option to ata. to do that power on the system and tap f2 at the dell logo. in the bios change the stat operations to ata. the option most likely is listed under drivers. you may also have to disble flash cache from the bios. once the option is disabled hit esc and save and exit. boot from the XP cd and run the setup. at the partations screen delete the c drive and partation it according to the size you need for xp and leave the rest for vista. install XP and the drivers from support.dell.com. After XP is ready to use put in the Vista DVD once in XP and install Vista on the unpartationed space left from the c drive.
Rate if helpful.
Jun 03, 2008 | Dell Inspiron 1501 Notebook
Xp Drivers for Dell Inspiron Laptop 1525
Dear Sir, Have Dell laptop Inspiron 1525 with Vista loaded....but I need Win XP-2 OS on it...CD of which I have but don't have the laptop drivers compatible with XP. Can you pls guide me how & where to find these drivers....Dell does'nt have those drivers anymore (outdated) Pls...
Apr 04, 2008 | Computers & Internet
Dell Keyboard for Inspiron 1420, 1520, 1521, 1525, 1526 Logo
186 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
