OKI C3200n Led Printer
Problem for OKI C3200n Led Printer
Smudgy Prints
By tvgal on Oct 22, 2007
Last month I replaced the black drum in my OKI C3200n. I did have some problems with it but finally got it working. For some reason this weekend though, it's started printing great black smudges on everything. I've not changed the toner cartridge nor done anything else. The printer is hooked directly to my computer and no one else has access to it. The smudges are so bad that the printer is for all practical purposes unusable.No matter how many sheets I run through it, the smudge doesn't fade. Can someone please tell me what needs to be cleaned so I can start using this printer again? I took the drum out and wiped off any excess toner I saw, but that just made it worse. Short of taking out the drum and dumping everything out of it and washing it off in the sink, I can't think of anything else to try.
Thanks!
twv@cdmfun.org
Solution #1
posted on Apr 08, 2008
Not Rated)
islandsole
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem with mine. Under the roller assembly there is a box which contains extra toner that is wasted from the printing process. It needs to be cleaned out periodically. It's this extra toner that gets put back onto papers as smudges, etc. I took my entire printer to Cartridge World where they took the roller assembly out and put it into a machine that uses bursts of air to **** out the extra toner (mine was full). I asked him why he didn't just disassemble the box from the roller assembly and he said that there are sensitive electronics that if moved would have to be resoldered. He said it was easier to use compressed air to take out the extra toner. Believe me, it was a mess and I wouldn't have wanted to do it at home. His machine was made for messes.
Was this helpful?
Yes
No
Solution #2
posted on Jan 09, 2008
Not Rated)
Soulvisitor
Rank: Guru  OKI Computer Hardware  Expert
Rating: 88%, 2356 votes
Never touch or clean drum surface, they are higly sensitive.
If as I suspect what you are seeing is toner not being cleaned from drum properly, these drum units have a rubber blade that wipes the drum as it passes it, some non oki toners are very abrasive and wear these blades out, sometimes the rubber is effected by heat or age, some after market drums use inferior cleaning blades in drum construction.
Are your 4 drums and toners the OKI genuine ones or did you purchase aftermarket/refurb/recycled?
Wiping the drum has probally scratched it's photosensitive surface.
Comments:
Jan 09, 2008
- Drums from OKI have a guaranteed life and are replaced with new if found faulty when life is above 50%.
Drums are not repairable.
I would not recommend using any non OKI product in your printer if you wish it to perform efficiently.
How many pages has this machine and its consumables done?
Was this helpful?
Yes
No
Popular Solutions for OKI C3200n Led Printer
Questions and Unsolved Problems for OKI C3200n Led Printer
Do you recommend OKI C3200n Led Printer?
Answer
Answer
I'm having some trouble with the color.
Answer
on color prints, along the borders is fine, the middle 4" +/- comes out faded, large contrast... (More)
Answer
i cant get the mac book pro to use the c3200 oki printer
Answer
okidata 3200n printing tire tracks on right side of page --- did a full cleaning of inside --... (More)
Answer
After about 85 - 100 pages printed it will say paper jam 381. There is one page half way out the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For OKI C3200n Led Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
