Question about RCA D52W19 52" Rear Projection Television
Need Service manual for a RCA D52W19 Projection TV
Need one that will show pinout of the power supply and motherboard.
  • 6 more comments
  • volcomschonk May 30, 2009
    TY, Do u know where I can get one for free?
  • volcomschonk May 31, 2009
    Does anyone have a pic of the main power supply connected to the TV?
    What plugs into there? Thanks
    Heres better pics....
    Not sure where it goes
    Ok i see. What about the left one?
    When plug the red and blue wire in I get a spark. is it ok?
    Brown and blue*
    I appreciate your help
  • RCA Master
  • 8,617 Answers
You can get one at the following link. They email then within minutes. Heres a link to the correct Manual as Thomson makes those TVs for RCA
http://servicemanuals.vstore.ca/product_info.php/pName/itc222/cName/thomson
Posted on May 30, 2009
  • 4 more comments
  • Sonny Berry
    Sonny Berry May 30, 2009
    you might try www.retrevo.com but most free service manuals dont have full schematics.
  • Sonny Berry
    Sonny Berry May 31, 2009
    heres the pic of the board its located on the right side of the tv where the power cord id attached to that board. Its the Main filter board
  • Sonny Berry
    The plug that is circled in your photo in red (right circle) in line with the large Capacitor goe to the two pins circled in the photo. There are two pins side by side on the board. The left set of pins is for your wire the other two are for the same color wires but they plug into the convergence power suply board above it.
  • Sonny Berry
    the red circle is hard to see its at the top of the photo left side next to the large capacitor
  • Sonny Berry
    The left terminals are usually not used in the ITC222 unless you have a built in DVD player. Its normal for that plug to spark when its plugged in as thats the AC input
  • Sonny Berry
    youre welcome let me know if you need further assistance.
WON'T POWER ON
Posted on Aug 24, 2012
RCA d52w19 service manual
Click the link below to download the Service manual for RCA D52W19
http://www.mediafire.com/?wci5e3o1l94htmc
Oct 19, 2011 | RCA D52W19 52" Rear Projection Television
Rca d52w19 rear projection changed flyback and cp150 cap. fuse fl231 is good . have bowed screen and 3d effect. convergence shows in menu but cannot adjust at all.
IF the FL231 fuse is good and you still can not adjust the convergence then the Convergence power supply board would be the most likely problem. You can get the replacement boards from www.tvrepairworld.com
Mar 31, 2011 | RCA D52W19 52" Rear Projection Television
Power supply, where can I get a power supply board.
if you know the compoment parts that need replacing yes if not order the whole replacment power bord from rca call there service parts number give them the tv model and they will be able to send you the entire replacment part
Jun 18, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 doesn't power up and have a picture
press and hold the power button for a few seconds. it should blink some codes. does your tv try and power itself on a few times. does it not show power at all. need more info to determine cause.
Jun 13, 2010 | RCA D52W19 52" Rear Projection Television
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
Rca hidef tv
Most likely a bad power supply module. The 3 tries is the 3 strike rule with the RCA TV's.
May 26, 2008 | RCA D52W19 52" Rear Projection Television
Power on/off
I had the same problem with an older model, try changing the batteries in the remote.
Dec 31, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
1,658 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
