Question about Cell Phones
No dial tone at my end when I ring a certain number even though the number I'm calling is ringing, also really slow to connect. all other numbers are fine
When using my cell phone, there is one number I call where I now get no dial tone at my end and there is a really slow connection to the number I'm calling, It does connect but I have no dial tone while it is ringing?
    Brigadier General:
  • 7,752 Answers
Dial tone but mobiles ahve no dial tone when making or receiving calls.....
Posted on May 30, 2009
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
Nov 17, 2009 | Sakar Talking Caller-ID Speaker Phone
My phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
My house phone rings when someone calls but we can't hear it ring nor can we get a dial tone to call out
The ringing you hear when you dial your phone number is not actually your phone ringing but a machine at the phone company designed to give you something to listen to while they connect your call. I would say that your phone number is working, just not at your house. You need to call repair to trace your phone line and get it connected properly. Good luck
Jul 17, 2008 | Lands Phones
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Unable to make or receive phonecalls
Your phone is barred. This means it has been blocked of making or receiving any calls.
Aug 18, 2007 | O2 Xda Orbit Smartphone
Cell Phones Logo
462 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
