Question about Sharp AR-M160 Laser Printer
How to reset all settings????????????
My Printer Sharp AR M160. how to reset setting?????????? Yuvaraj
  • 22 Answers
Reset code is c-photo-c-photo
Posted on May 30, 2009
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
My printer blanking "ch"
Check the correct instalation of the developing unit.
Jan 28, 2010 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
I WANT A PRINTER DRIVER FOR SHARP AR-M160
follow the link below:-
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
plz rate the solution...
Nov 14, 2009 | Televison & Video
Where to get driver for Sharp AR-M160 for Windows 7
http://www.bioticaindia.com/ar-m160.html
Here is a link to a driver you can try. It is very possible that there is not a driver available that is compatible.
Thank you,
lee
Nov 10, 2009 | Sharp AR-M160 Laser Printer
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Can't disable / remove "Print Status Window" on Sharp Ar-M160/M200
Remove the printer software and use a generic Windows driver. That is the only way, since the status window is part of the driver software. If the printer is postscript enabled you can almost always use the HP laserjet 4 driver which is basically generic postscript.
Jul 29, 2008 | Sharp AR-M160 Laser Printer
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
Scanner problem
Here is a list of drivers.. Since I do NOT know your OS, this page has MANY OS options...
Good Luck
May 30, 2008 | Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Laser Printer Logo
382 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
