Question about Polaroid PDV-0823A Portable DVD Player
Polaroid pdv-0821t portaable dvd
Comes on plyes the disc but no picture
5 Suggested Answers
SOURCE: Polaroid DVD player (portable) PDV-0707N
Buy a new one.
Posted on Jan 26, 2008
  • 2071 Answers
SOURCE: player freezes partway through movie
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Posted on Sep 06, 2008
  • 115 Answers
SOURCE: I have a polaroid dvd player model pdv-0700 that
make sure there is no streak on your dvd, and make sure the lids closd well. Try to use another dvd media
Posted on Mar 04, 2010
  • 29 Answers
SOURCE: I have a Polaroid PDV-0701A portable DVD player with power input
same problem here !!
Posted on Mar 14, 2010
SOURCE: I have the Polaroid dvd
The PDV0701A will not power on and screen is black . If you turn switch off white lines appear on screen as it turnes off . No sound and dics does not move . Please advise .
Posted on Aug 11, 2010
0 characters
1 Points
Disc does not load
Maybe because the disc is dirty or someone messed up your dvd playeer
Jan 01, 2011 | Polaroid PDV-0820T Portable DVD Player...
MIssing Part and I don't know what it is called
Email me your address and I will send you one.
PS include a note to remind me what you need.
Dec 12, 2008 | Polaroid PDV-0700 Portable DVD Player
I'm having a problem similar to those describe regarding the drop off of the picture during dvd playback. However I noitced that if I plug the player in directly, rather then just running it on the...
The problem of Polaroid DVD-players is too suggen cuttofs during playback. Usually there is no "low battery" warning 5 minutes before it just cuttofs. Usually it has 4 hours playback time.
Probably you need to replace the battery.
More information you can read here.
Good Luck
Dec 07, 2008 | Polaroid PDV-0700 Portable DVD Player
Car Adaptor
here is an free 800 number you can call and ask the techs to make positive friend
Polaroid electronics
Hope that fixya up there
Nov 19, 2007 | Polaroid PDV-0700 Portable DVD Player
Troubleshooting pdv-0800
The usual reason for a drive to report "No Disc" is that the Reader eye is dirty or past its servicable life. this will be shortened in a Smoky or Dusty environment, A Cleaning disc (Preferably wet and dry) in the drive may solve the problem if the drive is dirty, if not then a replacment reader or drive are the only options.
If the Player is still within warranty I suggest you send it n.
Nov 04, 2007 | Polaroid PDV-0800 Portable DVD Player with...
Player freezes partway through movie
If this happens on all disk and you have cleaned with proper laser disc cleaner there are small caps that are almost naked to the eye that needs changing in power supply
Feb 01, 2007 | Polaroid PDV-0700 Portable DVD Player
Polaroid PDV-0823A Portable DVD Player Logo
46 people viewed this question
Top Polaroid DVD & Blu-Ray Players Experts
Jonathon summesfield
sonic boom...
sonic boom...
Are you a Polaroid DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
