Question about Intel D101GGC Motherboard
Ddr 2 ram connecting to intel d101 motherboard
Hi All,
I had intel d101 mother board, which ishaving ddr ram of 512 MB, now i want to upgrade it using ddr2. i know that is not the supported for my motherboard. i want to know is there any connector is available, in order to connect ddr2 ram to intel d101 motherboard
  • 408 Answers
Well first of all, there is no "adapter".  You have to use the specified RAM that you motherboard supports.  Secondly, even if there was an adapter so to speak, it would not be beneficial.  The only difference performance wise between DDR and DDR2 is speed.  So if your motherboard supports DDR, and you had an "adapter", your motherboard would only read the DDR2 at DDR speed.  In my opinion, DDR2 is not really worth the upgrade to another motherboard just for DDR2.  If you want the biggest bang for your buck, upgrade the CPU, or put more memory in the motherboard you already have.  Hope this helps, and please don't forget to rate.  Thanks.
Posted on May 30, 2009
  • 822 Answers
No you cannot upgrade. there is no connector also to upgrade. you must change the motherboard if you want to upgrade to DDR2.
  • 344 Answers
I wouldn't think so the 2 memory types run on different voltages, although I think Gigabyte have a motherboard that has both slot types though it won't help you I'm afraid.
    President:
  • 156 Answers
Hey Hi,
Well Unfortunately There Is No Connector For Installing DDR2 RAM In This Motherboard. You Can Check It On The Link below
Click Here For The Link
However, if u can spend some money then you can go ahead and INSTALL a NEW PROCESSOR to increase the speed of the system...
Supported Processor Link
Click Here For More Support Information
Tell me if u need further help
My mboard have 4 slot of RAM DDR, but i can't put all my RAM on all (4) slot, only 3 slot my comp can read (my RAM is DDR 512 MB pc3200 x 4) soo.. i have 1 Free DDR 512 and 1 slot.. please..please guide...
Looks like you have the right kind...they have to match you know...you could try 2/1g sticks instead...
Your compatible memory is here: http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/p5gpl-x
Jul 22, 2017 | ASUS P5GPL-X SE Motherboard
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Hi, I wish to upgrade my Ram speed from 256
Hi friend,
You can use more then 2GB Ram in your motherboard. it should be DDR-1 Ram .....you can change..
Dec 28, 2009 | Intel Motherboard
Hi All, I had intel d101 mother board, which ishaving ddr ram of 512 MB, now i want to upgrade it using ddr2. i know that is not the supported for my motherboard. i want to know is there any connector is...
It used to be a waste of time and the only solution was another MB. Now they have come up with higher value ddr's (I think they call them 2 in one). If these ddr's are available, then all you will need is to raise the CPU chip voltage. You have to give me the CPU speed in Mhz. I see it as a good possiblity to update the computer with more RAM and raise the frequency to make it faster. You can get some life out of the computer and then sell it and replace it with another new computer. I have worked with all kinds of mother borads. There are some very good and expensive ones (which are not any better than the others). There are also some expensive mother boards that are plain no good. In my years of experience, if I needed a new mother board, I would buy one of the various models that they curently have. The name of the company is PCCHIPS from Taiwan. I have three so far for my own personal use and I am happy. I started to ask you about the CPU speed and forgot to ask you to let me see it. This way we can make our decision, upgrade MB and speed up the CPU vs. Buy another MB vs. buy another computer. Remember that jut about all computers perform equally. Equally, it is the reliability. I have three laptops we use for travel: one Compaq, that after 8 months we had to replace the MB du to problems. New MB's are more reliable than OEM. My other computer is a 1600 series ACER. About a month after the buy, I lost the CD/DVD drive. Other than that, everything works.... The third one is a business computer by PH. It works and works and works... 3 years now. They have a good blower, unusual for the run of the mill, the computer is mostly cool, even when I have to leave on for overnight VOIP calls. My name is Constantin (arzconst is my nickname assigned by my employer Fixya.com)
Jun 13, 2009 | Intel D101GGC Motherboard
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Intel D101GGC Motherboard Logo
377 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
