Turned My Advent TV off to go away for a few days on returning switched it back to on only to find it wont turn on
  • 2 more comments
  • royshore May 30, 2009
    My tv is not a projection tv it is a 32" lcd there is no reset botton anywhere on the tv
    The power plug and fuse have been checked anyway the red warning light on the front that usually turns green when the lcd screen has a picture. is flashing red and the screen remains black
    regards roy shore
    No transformer outside the tv and i dont know enough to start messing with the inside
    thankyou can't get anybody because they cannot get parts but will keep trying
  • 3,230 Answers
Check the back of the t.v. for a RED RESET BUTTON.
if you have one push it in.
make sure it's not the plug itself. try giggling the plug and turning on the t.v. at the same time.
to unplug it and plug it back in should be the right thing to do.
I don't see that as being a reason for it not to work.
Regards
all-guru
Posted on May 30, 2009
  • 1 more comment
  • Mukesh Kumar May 30, 2009
    Ok..
    It seems that there is a fault on the transformar of that TV.
    Do some check with using a multimeter....
    1. check the power plug and cable
    2. check the fuse.
    3. check the transformar.
    post further comment for more help.
    thanks
    Yes..
    Problem seems like same, as I say.
    That sorry but the transformar is inside your TV, So better if u get help from a repairman.
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
I have an advent tv/dvd combo. I dont have a remote and its stuck on video. how can I put it on tv without the remote? thank you
Disconnect the TV\DVD combo from power source (A\C) for two to three days, Replug power cord & see if it returns to normal. 2nd attempt:: Unplug A\C power from wall and take a piece of bear wire or any metal (paper clip, screw driver ) and SHORT the two blades of A\C plug for at least one FULL day.DO NOT PLUG INTO a\c SOCKET FOR ANY REASON !!! After one full day, take the short accross the blades. Replug into A\C power socket. see if that fixes the problem. P.S. Your TV should have a button that switches from TV to DVD play right in the right front.
Jun 19, 2011 | Recoton Advent Advent DV1418A 14 in....
I have a 15 inch Advent LCD TV in my kitchen. I turned it on today and have no picture. When I switch stations I get a picture for a minute then it is replaced with vertical lines or a blank screen with...
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 11, 2010 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Advent ht3251a wont turn on
working on same model same symtons,pluged sys into a vareact tv came on normal,problem gone.set works ok when plug into ac outlet.can,t say what cause problem,set work ok now without veriact.will air test three days to see if probem returns.will try freez spay on chips.
Feb 20, 2009 | Recoton Advent Advent HT3251A TV
Black Square
I had the same problem with DVDs. It turrned out that I turned the closed caption on a few days earlier, so I turned the "closed caption" off and the problem went away.
Jan 30, 2009 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
My new LG LCD TV (3 days old!) suddenly started playing up, last night. I was initially using the receiver unit (with built-in DVD) to play a disc of MPG files, which it did successfully. Then, I tried to...
Good thing the tv is under warranty, theres no magical fix for a problem like this. I would either return it to the store or call for service. If you atempt to do to much to fix it you might voide the warranty, and you should have to do anything to fix it as you said its 3 days old.
Tim Nolan
Sep 24, 2008 | Televison & Video
Istalling mouseb has turned off touch pad ?
This usually happens so you dont have 2 mice running at once. Unplug the new mouse and your touchpad should come back.
Mar 12, 2008 | Recoton Advent Advent Q2035A 20" TV
Colors on tv
Can you tell me if you have s[eaers on or near the TV? If so It may be possible that the TV is being affected by the speakers being too close if that is the case. If so then to move them of or away and to turn the TV off for 30 min should solve it. Hope this helps.
Feb 16, 2008 | Durabrand DWT1905 TV
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Jan 19, 2008 | RCA F27442 27" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
