Question about Exercise & Fitness
Your Problem: jazfit-750 Treadmill motor will not turn on
I have a Spirit model 774P Cushion Flex treadmill. Has been running fine. today when i turned it on the tread would not run. Motor appears to be fine, not frozen and it does not smell as if it were burnt. I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good. All other functions of the treadmill appear to be working fine. When primary power is turned on a light on the primry power pc board comes on but doesn't appear to be getting to the motor. There is another pc board involved. not sure where to go from here. I noticed there is no Sporting equipment expert so I am just taking a shot. PS couldn't find my model listed so I just picked one. treadmill does not work, power is on but won;t start and after 10 second the light come off
    Habit-Forming:
    New Friend:
  • 25 Answers
DEAR
AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
Posted on Apr 10, 2017
2 Suggested Answers
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
Jazfit txo
see the video and proceed according. Lube the rollers bearing front+back with silicon or wax( depend of your mark, model) read your owner manual.
God bless you
Oct 18, 2013 | Icon Epic T60 Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Belt won't turn.
HI, please replace the control board
Sep 29, 2009 | Spirit Esprit ET4 Treadmill
Error 4 Deplay showing Over current
hai,
error4, display board maybe not fine
Aug 10, 2009 | Spirit Esprit ET4 Treadmill
WANT TO REMOVE THE MOTOR FROM SPIRIT TREADMILL TO SEE IF IT CAN BE FIXED. HOW TO ?
Remove cover at front of treadmill,4 pillips screws on each side, 2 screws at front. Lift off plastic cover. Loosen motor belt tightener at top of motor mount ,remove 4 11/16 " nuts holding motor to treadmill base, remove red and black motor wires from control board. Lift motor out.
Aug 04, 2009 | Spirit Exercise & Fitness
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
May 15, 2009 | Spirit Esprit ET4 Treadmill
Exercise & Fitness Logo
693 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
