Home | Acer | (ACERMOTHERBOARD) | ACER ASPIRE 7520 NO CHA...
Acer
Problem for Acer (ACERMOTHERBOARD)
ACER ASPIRE 7520 NO CHARGING, NO RUN ON MAIN, RUN ON BATERY ONLY
By spaja1 on May 30, 2009
my laptop fell on the floor,no charging since, I pull the motherboard out but did not find any visible damage.
Best Solution
posted on May 30, 2009
Very Helpful)
ArcAiN6
Rank: Wiz
Rating: 82%, 84 votes
You cannot visually inspect laptop components to verify component level damage. You may have damages something in the motherboard tracers, or popped a solder loose, or worse, created a micro fracture in one of the surface mounted chips.
Before going further, i would suggest you thoroughly test the battery, or power supply for charging the laptop, as well as make sure the power connector jack on the motherboard is not damaged in any way. If the jack is the problem, they are quite easy to replace, but knowledge with soldering on delicate components may be necessary.
I would have suggested requesting an RMA if the laptop was still under warranty, but by removing the motherboard to inspect it, you have voided any warranty you may have had.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 20, 2009
Not Rated)
alexprabha18
Rank: Apprentice
Rating: 0%, 0 votes
hello sir,my laptop is acer aspire 7520 no charging,no run on main,run on battry only,laptop power adaptor led is damage,
Was this helpful?
Yes
No
Popular Solutions for Acer
Questions and Unsolved Problems for Acer
Do you recommend Acer (ACERMOTHERBOARD)?
Answer
Answer
i am having intel DG13PR mother board, now iam having front panel mic and line out connections, now... (More)
Answer
Original arcade game Space Invaders, may need new motherboard. Screen image has many vertical lines... (More)
Answer
vaio atom n270 1.6GHz no sound, limited resolutions
Answer
this acer Aspire 3100 does not recognize ther internal or external keyboard and mouse each time that... (More)
Answer
I have an ACER laptop, when I press the ON switch the machine just goes from ON to OFF continually. ... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer :
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14143
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
