Question about HP Compaq Presario C700T
Laptop not show cd or dvd when i put it
Hi sir i have a laptop of compaq c700. when i put CD or DVD it does not show it,now i want to instal window xp from cd disk but laptop does not show cd and how i install window xp. sir please give me suggestion want i can do to solve my problem.
  • 408 Answers
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
Posted on May 30, 2009
My dvd/cd driver was not working.so ihave remove my dvd/cd rewritable drive for some maintenance.now i connect the driver in laptop i didnt found icon in (divices with removeable storage)in my laptop....
Check to make sure it is seated properly
depending on what kind of maintance you did it may have to be replaced
the only maintance that is required is an ocassional cleaning with a DVD disk cleaner do not remove and take a part
Jul 27, 2009 | Computers & Internet
DVD burning problem
Hi guys .. it was very simple... Some laptops (such as mine Compaq Presario C755TU) are meant for WINDOWS VISTA .. Certain features will work only with VISTA.. i removed XP and installed VISTA and it's working fine.. life is beautiful again !
May 17, 2009 | Compaq Computers & Internet
HDD Problem
Your computer uses a SATA hard drive and XP does not natively support SATA drives. You can go to http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html to find instructions on how to create a new XP disk with the necessary SATA drivers slipstreamed into the installation which will allow you to install XP on your computerr.
Mar 28, 2009 | Compaq Presario C700T Notebook
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Jan 24, 2009 | Compaq Presario C700T Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
No sound can
hello. sir. i have lost sound from my lap top Compaq presario C700 after installing windows XP. kindly help me. my laptop is also showing pproblem during installation of hard drive for same driver, every time i turn on my laptop. i donot have the installation mother board for the same laptop
Jul 13, 2008 | Compaq Ensoniq AudioPCI Sound Card
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
HP Compaq Presario C700T Logo
140 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
