Hi, I own a InFocus ScreenPlay 777, and am having troubles connecting HDMI to it. I had installed the adaptor I got from InFocus themselves to the projector's DVI (M1-DA) socket, and connected the HDMI cable. Having chosen the correct source socket on the projector, I've got no video. Would anyone know what else I need to do to get HDMI vision?
  • krobbie71 May 30, 2009
    I am not a novice to Hi Fi. This problem needs someone with expert knowledge on the Particular model, ScreenPlay 777, by InFocus. I have done all the usual "reset" method, and they don't work. According to the website of InFocus, which gives technical support, my projector should be working, EXACTLY as it is. The projector is working for video on other formats, but NOT HDMI.
    The cable into the InFocus's special adaptor into the DVI (M1-DA) socket, *is* a HDMI cable, not a DVI cable.
  • 3,230 Answers
First of all remove the DVI cable from your projector.
Just plug the HDMI cable not the DVI.
Thanks
Posted on May 30, 2009
  • Mukesh Kumar May 30, 2009
    So.. u use a HDMI cable saperately.
    President:
  • 1,383 Answers
First check all connection again .
And reset alls ettings to factory dwefualts.
Tehe is 1 reset button.
If not then press power button for 10 seconds.Aslo pull the power code for 10 minutes frokm it so it hardreset.
Then check .
  • kishor
    kishor May 30, 2009
    check your resolution is set to 1024*768 it is most perfact resolution.
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
InFocus Screenplay 4805 to PS3 Playstation 3 - Blank screen
Try pressing the "auto image" button on the projector itself. This usually will correct the sync problem.
Feb 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
Replaced bulb in infocus 777 and background is red not black
Its not the bulb. I have repaired a few of these with color issues. and its caused by short wires that nearly pull out of were there plugged in at. A big fail on the part of the manufacturer.
you have to open it up and check all the wire connectors. Even a plug thats slightly pulled out can cause issues.
Feb 12, 2009 | InFocus ScreenPlay 777 Multimedia...
Screenplay 5700
Because these units have dangerous high voltages inside, there are a number of safety interlocks throughout. Take out the lamp and reseat it. Also, make sure that the access door is installed correctly and securely. Both have interlocks that will prevent a poiwer up is not installed correctly.
If this is not the case for you, please update this and we'll look for other causes.
Thanks,
Dan
Jan 05, 2009 | InFocus ScreenPlay 5700 Multimedia...
Infocus screenplay 4805 not communicating with PS3 console.
Try pressing the "auto image" button on the projector itself. This sometimes solves these types of problems.
Nov 15, 2008 | InFocus ScreenPlay 4805 Multimedia...
Colors showing red on screen
Hi Stella,
There is a button on the projector called "Auto Image"
Most people don't realize it's even there.
Press it while you are seeing this problem and most likely the projector will figure out the image issue and all will be well.
Note: this feature is nowhere in the menu(s)
Good Luck!
SagerTronics
Oct 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
INFOCUS Screenplay LCD projector...
Hi there
I take it the Projector is ceiling mounted ?
If this is the case check that it is installed with the lens of the Projector in the facing straight to the middle of the screen or try adjusting the bracket's swivel head to move it a bit - should do the trick !
May 10, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus Screenplay 7205 Projector
Hi there
It might be a small IC that has gone on the Powerboard , I wouldn't worry about it if I were you.
Apr 14, 2008 | InFocus ScreenPlay 7205 Multimedia...
Hdmi interface not working on the ScreenPlay 61md10
I've had that problem before and it turned out that, although it looked absolutely fine, it was my HDMI cable which was not working. After getting a high quality cable, the problem went away.
Feb 19, 2008 | InFocus ScreenPlay 61" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
