Question about Sony PlayStation 2 (PS2) Console
PS2 Memory Card "Unformatted"
Error loading comes up when i put memory card in my brother turned on the ps3 and out of nowhere came a notice or a note saying "Your memory card is unformatted, Would you like to Format?" I don't want to lose all my data what should I do? My StreetFighter,KingdomHearts I and II,mortalkombat,and others. My memory card is "Max Memory 32mb"
  • jin_masta May 30, 2009
    can someone please help me!!!!!
  • Tualiapz
    Tualiapz May 11, 2010
    you are putting a PS2 memory card into a PS3?
DNT FORMAT IT if you do then it will just unformat its self when you turn it back on i have the same problem if i was you i would try deleting some stuff off the memory card (turn the play station on with out a disk in and click on memory card) than delete some old data you dont want. but if that still dont work then try blowing in the memory card (it might be a bit old). after you have done all of these things and it still dont work then i would go on a website about sony play stations and unformating memory cards, and there will be a phone number ring it tell them whats happened and they will surly send you a new memory card but that would meen your old memory card would have to go in the bin :( its a plesure to help.
Posted on Jun 28, 2009
I have no manual my problem is I have a First Generaiton Ps3 and would like to transfer my Ps2 memory card and cant figure it out. pleae help thank you Nichole
Prerequisites There is no PS2 memory card slot in the PS3 so will need a Memory Card Adaptor. Sony made an official adapter but there are also a number of cheaper alternatives. Buy one online:
Steps
  1. Plug your PS2 memory card into the adaptor
  2. Plug the adaptor into a free USB port on your PS3
  3. Go to the "Game" menu in the XMB and choose "Memory Card Utility (PS/PS2)"
  4. If the adaptor is working you should see an item called "Memory Card (PS2)". Below the title should be the size of the card and how much is in use-in my case "1334 KB / 7998 KB"
  5. Press the controller's Triange button to get the Memory Card options. Select "Copy"
  6. Select "Yes" to confirm the copy from memory card to the hard drive
  7. Enter a name for the new Internal Memory Card that will be created on the hard drive, or leave the default name. I named mine "Original PS2 saves". Select "OK"
  8. The data will be copied. If the amount of saved data is too large, the system will automatically create multiple internal memory cards
  9. You may be informed that the new internal card has been assigned to a "slot". These slots are an emulation of the physical memory card slots in the PS2, so similarly you may only have two internal/virtual cards "plugged in" (assigned) at a time. The internal memory card must be assigned to slot 1 or 2 to be available when you run PS2 games
  10. The new internal memory card should now be showing in the XMB, under Game > Memory Card Utility
  11. Selecting the card will allow you to browse the game saves that were copied across!
Jan 04, 2011 | Video Game Consoles & Games
How do you put your ps2 memory card in ps3 I have a backwards compatable one and need to know how to insert ps2 memory card into ps3
You Cant its not made for Ps3 var fctb_tool=null; function YOns_s9xY4_L(t) { fctb_tool=t; start(fctb_tool); }
Dec 22, 2010 | Sony PlayStation® 3 (60 GB) Console
My pS3 slim 120gb will not save pS2 game data
Hi,my ps3 is not a slim version so hope this works ok for you.Return to your ps3 hard drive interface, go to 'game' then 'memory card utility' and create an internal memory card,but to get Abes Odsysee to work you must create the memory card in 'ps' format not 'ps2' worked for me,hope this helps.
Apr 17, 2010 | Sony Playstation 3 (PS3) Console
Can not create internal memory card, whenever I try I returned back to the screen that says name a internal memory card.
http://ps3explained.com/intermediate/internal-memory-cards/
Create an Internal Memory Card on the PLAYSTATION 3 system HDD as follows:
1. Navigate to [Memory Card Utility (PS/PS2)] under [Game] on the XMB.
2. Press “X” to bring up the “New Internal Memory Card” option.
3. Tell the PLAYSTATION 3 which format you want it to create. PS2 or PS1.
4. Highlight “OK” and press “X” to finish creating the memory card.
Note that you can make new saves on this card while playing PS2 or PS1 games on the PS3, but it does not allow you to transfer saves from a physical memory card to the PS3's HDD. You need the memory card adapter to do that.
Apr 06, 2010 | Sony PlayStation® 3 (80GB) Console
Have a ps3 120 slim. is there any way to play ps2 games?
Yes of course, thats what tops the ps3 i believe, go to game, memory card utility (ps/ps2), create new internal memory card, choose ps2, name it, ok, then put in ps2 game and it will act like a ps2! Regards
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
I cant save sim city 2000 on my ps3
Make room free on your ps3's harddisk, this is where al data on your ps3 is stored.
Some games install alot game data, resulting in a harddisk thats is full.
Remove game data from games that you're not planning to play any more soon.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
No data
Sounds like the memory card became corrupted, beware of buying massive memory data cards for ps2 as the bigger they are the more chance of problems, sounds like you will have to get new card.
May 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
1,020 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
