Question about Carter Yosemite Home D?©cor - Polished Cream and Brown Onyx Sink
Fuel problem ???
Fuel pump quit replaced pump ran for a 15 min drive then next day dozent start no pump noise checked power good check ground no ground replace to new ground on frame starts runs poor seems like not enough fuel presure
    President:
  • 3,433 Answers
Filter must always be changed when pump is. replaced.
Posted on May 30, 2009
1998 f250 5.4l would not start. changed feul pump and filter still would not start. 20 mni later started. was cleaning engine while running 10 15 min later died wont start.
Check fuel pressure at the injector rail. Could be your fuel pump relay is cutting out. If fuel pressure is good, check for sparks at the plug wires. Read the link below for more info.
Do It Yourself Diagnosis and Repair
Jul 26, 2017 | Cars & Trucks
Engine shuts off after driving 45 min when parking in reverse.But 15 min before this engine and slippery road icon comes on.2 hrs later car starts and drives normal then shuts off again 45 min later.
most commonly found problem relates to an electronic component heating up and shutting down. Have you checked to confirm there is fuel pressure when the vehicle shuts off. Is the check engine light on. Have you checked codes ? I suggest hooking up a fuel pressure gauge and letting vehicle run till it shuts off while monitoring the fuel pressure. If you loose fuel pressure, next step is to confirm there power going to the pump, if there is power going to the pump with no fuel pressure replace pump. Another suggestion would be to check for spark when vehicle stops running to eliminate an ignition problem. good luck
Aug 17, 2015 | 2008 Toyota Highlander
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Jul 20, 2013 | Cars & Trucks
My 94 929 mazda won't start
You probably have a blown head gasket, not allowing you to get enough compression built to start the engine.
Rent a compression tester from AutoZone (You get your money back when you take it back) and use it. If the compression on each cylinder is less than 100 PSI, you've got some issues. The cylinders should also be somewhat balanced.
Jul 22, 2010 | 1994 Mazda 929
Jeep Cherokee Sport 1993 stalls after start up fuel pump issues
good morning to you and welcome to fixya.com. hope we can get you fixed here. just a couple of questions first? have you changed the fuel pump yet? if so where did you buy the pump from? your pump is actually building up to much resistence and is unable to overcome it in turn no power is getting to pump as needed. i have a grand cherokee with 230k so i love hearing that you have that many miles. lets keep you rolling. let me know and ill help you out.
Feb 28, 2009 | 1996 Jeep Grand Cherokee
Car troubleshooting
i will put 5 gallons of gas then have some one turn the ignition on while listening to the water pump if you hear a noise coming from the fill up hole then most likely your water pump is good is not i will check fuel pump rellay and fuse replace as necesary check pupm sound if no sound replace fuel pump.
Jun 21, 2008 | 1994 Chevrolet Caprice Classic
Carter Yosemite Home D?©cor - Polished Cream and Brown Onyx Sink Logo
70 people viewed this question
Top Carter Home Experts
john h
Tom Chichester
Are you a Carter Home Expert? Answer questions, earn points and help others
