Question about HP Photosmart C6180 All-In-One InkJet Printer
C2FE0100 Error My Printer only show "Turn power off, then on again" C2FE0100. When I turn it off and on again, it still show that... What's the problem??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Please check the link to HP support for you issue on your printer. The error fix is for "Turn power off, then on again" displaying on the control panel.
Please take the time to go through the troubleshooting steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&cc=uk&lc=en&dlc=en&product=1153494
Please rate if this help to fix your issue
Posted on May 30, 2009
Error C2FE0100
OK, here are a couple of ideas to resolve the issue:
1. Hard reset - turn the printer off, hold the # and 6 keys while and a bit after turning it back on.
2. Remove the ink cartridges, then the printhead (via the gray lever on the right of the carriage). Reassemble and retest.
Apr 23, 2013 | HP Office Equipment & Supplies
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Show the error light
Hi Karthik,
Try this:-
  • Check the paper roll and probably re load it.
  • Turn the printer off.
  • Press and hold the power button and then switch the printer on.
  • Release after the first flash of LED light.
  • The printer prints a test page.
  • Turn it off and then on again and then try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Citizen CTS651 Thermal Printer
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
Hp lj9050 error 5803
IT IS A CPU PROBLEM
Turn off the printer, and then
turn the printer on again to
continue.
2 Check the printer
configuration.
3 Replace the print cartridge.
4 Replace the toner sensor
contact assembly.
5 Replace the DC controller.
Mar 19, 2010 | HP LaserJet 9050 Printer
HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Jan 08, 2010 | HP Photosmart Premium C309A All-In-One...
Shows 1203 error on lexmark P4350
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Nov 01, 2009 | Lexmark P4350 All-In-One InkJet Printer
My canon LBP5200 does all the usual whirring and stuff as if its about to print, when the paper feed normally starts instead the alarm light flashes and the following shows on screen :- Printer error....
The fuser unit is faulty.It sits at the back of the printer and disconnects by unlocking 2 blue levers.reseat it and try again,if not you need a new fuser
Aug 06, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
2,516 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
