Question about Tomtom ONE XL GPS
Tomtom fuses i have a blown fuses in my tomtom one xl charger but dont know what the amp/voltage is on the fuses as there is no writing, and do you know where to get one, thanks tomtony
Have you got an iPod charger ? With a USB connection ? Or a Blackberry charger ? These are standard USB chargers these will work
Posted on Jun 06, 2009
    Habit-Forming:
  • 35 Answers
Take both the charger (which should have a output rating on it) and the blown fuses down to Radio Shack, Jack. They'll help you out.
Posted on May 30, 2009
I push start button and hold this more than 2 seconds but the starting screen is not opening i also connect to battery charger from car and then pushing again to start but no reaction i have tomtom...
The issue could be a low power in the Tomtom and that is the reason it is not switching on. Now here the problem could be with the charging cable/wire from the car charger which might not be giving power to the GPS. Check for the fuse at the connector.
If the fuse is blown off the power wont goes into the GPS and it wont get charged and wont swich on. Look at the tip of the connector which has that spring like contact. You will be able to turn that to open it and find a fuse. Replace it with the right "amp" as the existing one. You will get one from Radioshack.
If you have already checked it and sure it is charging could be issue with Tomtom itself..Good luckKris..
Jun 18, 2011 | Tomtom ONE XL GPS
We have a Tomtom XL with a cigarette lighter connector; our car does not haveone of these . Is there an alternative cable/connector?
the only alternative is to hardwire it into the car, and you must utilize the car charger to supply the correct voltage (you can not supply 12V or it will blow out your tomtom)
your tomtom will not take more then 5v @ 2 amps so you need to go through the car charger by taking it apart and attaching the power from the car to the car charger input leads.
i dont recommend you try this if you do not fully understand what im saying, because you can easily ruin your gps by hooking it up wrong.
any decent mechanic should be able to do this in less then 20 minutes.
curious as to what kind of car you have that doesn't have some sort of aux power.
have you looked under the dash or the clove box...sometimes they are put out of sight, but i dont think i have ever seen a car without one.
Jan 06, 2010 | Tomtom One XL GPS Receiver
I recently purchased the tomtom 340S XL. Can it
Using cable data /charger port you can do charging both at system or in car under car charger option. those specifications placed in manual and normally lasts for 3 hours
Dec 16, 2009 | Tomtom XL 340S Car GPS Receiver
My tomtom wont charge through car charger or pc
It is possible that the cvar charger fuse has blown. Undo the tip and remove and replace !amp fuse and all should be fixed.
Please rate my help++++Thanks for using FIXYA
Dec 08, 2009 | Tomtom ONE 3rd Edition GPS
Charger
I had the same exact problem! It should plug in to the back of the unit, but it wouldnt charge there either.
What i had to do was goto Radio Shack and buy a Universal Charger for my cigarette lighter that cost $14.00. It has multiple plugs and 'pins'. Find the right one, and set the volt/amp switch to 4 or 6 amps, whatever it says on the bottom of your TOM TOM. The person at Radio Shack helped me, they should be able to help you too!
Thanks,
Mark
Dec 30, 2008 | Tomtom One XL GPS Receiver
TomTom XL Text-to-Speech not working
I had the same problem, before realising that text-to-speech on the TomTom XL on'y works if you've selected a *computer-generated" voice - and not all of them are. "Samantha/English-US" is computer-generated, for example, but "Tim/English-UK" is not (it's a recorded voice). When choosing from options in the "Change voice" menu option, check the top-right hand corner to tell whether a voice is computer-generated or not. Hope this helps.
Dec 03, 2008 | Tomtom One XL GPS Receiver
Tomtom 910
I dont think so. The unit runs on 5 volts (why I dont know!!!) so the first thing to fry on a 12v hit is the on-off switch then some of the components. Sorry
Jul 25, 2008 | Tomtom GO 910 GPS Receiver
Can i plug my tomtom 1 xL in to a 24v cigerate plug
Hello callan_1,
The USB car charger which TomTom makes for the One XL GPS receiver appears to support cigarette lighters with voltage from 12 to 24 volts. If you have this charger you should be able to use it power your GPS.
Best Regards,
Ken
"Go Ahead Use Us."
Jun 24, 2008 | GPS
Require value of D5
TomTom One uses a Linear Technologies chip LTC3455 as a USB/charger power controller. See http://cds.linear.com/docs/Datasheet/3455fc.pdf. This chip is susceptible to high transient voltages that result from resonances created by parasitic inductances and capacitances of the USB/in-car charger cable . Good designs using this chip suggest that a 1 ohm resistance be put in the path of the cable to reduce the Q of the resonance and hence transient voltages. A 6V Zener diode D5 also serves to protect the chip from these transients.
If the Zener diode is blown it is most likely the the LTC3455 chip is gone as well. You can replace the chip which costs £5.00 (located in the shielded portion of the PCB). The recommended Zener Diodes for this chip are either the EDZ5.6B or EDZ6.2B manufactured by ROHM (http://www.rohm.com/products/databook/di/pdf/edz5.6b.pdf or http://www.rohm.com/products/databook/di/pdf/edz6.2b.pdf). These can be used to replace D5. The STMicroeletronics SM2T6V8A can also be used to replace D5 (http://www.st.com/stonline/products/literature/ds/8694/sm2t.pdf). All the Zeners cost a modest £0.22. I hope this is helpful.
Emmanuel Zyambo
Jun 15, 2008 | Tomtom One XL GPS Receiver
Tomtom ONE XL GPS Logo
348 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
