Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
Windows install problem
After format HDD and copy system files by Widows XP Professional SP1a Operating System CD, can't book Windows from HDD.
  • jpsun May 31, 2009
    follow your instruction boot only from cd (D drive) of winxp boot disk and then chkdsk C and can view drive A, C, and D files but still can not book from C. On C root, there are files of ntldr 233632, NTDETECT.COM 47580, NTBOOT.SYS 24448 AND boot.ini 215 and dir. of WINDOWS.
    Thanks
    President:
  • 1,383 Answers
  • kishor
    kishor May 30, 2009
    Sorery for above post by mistake post to your problerm
    ok
    If it not load check in bios that yourt ahrddisk is detected or not.
    Load optimal defauls in bios then save .
    then check .
    If problem still remain u mhave to boot your computer with winxp boot disk then go to recovery console and type there "chkdsk /r"
    thehn press "y"
    then it fix error on harddiski.
    Some time svirus cause this problem so u have to delete all partriton and format again u can do it.
Windows xp ulcpc note book emachines..system 32 rundll.exe
system 32 rundll.exe b> To resolve these problems, follow these steps: Restart the computer in safe mode: Restart your computer. While your computer is starting, repeatedly press the F8 key on your keyboard. On a computer that is configured to run under multiple operating systems, you can press the F8 key when the Boot menu appears. When the Windows Advanced Options menu appears, select an option, and then press ENTER. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom of the screen, select the installation that you want to start, and then press ENTER. Open My Computer, and then open the C:\Windows\INF folder. Right-click the sr.inf file, and then click Install. When the installation process has completed, restart the computer. If you continue to experience one or more of the problems that the "Symptoms" section describes after you have completed the previous steps, restart the computer in safe mode, and then reinstall Windows XP SP1a or install the latest Windows XP service pack.
To obtain Windows XP SP1a, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0136e5f8-1684-4202-b2d0-c6a43430f12a&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0136e5f8-1684-4202-b2d0-c6a43430f12a&displaylang=en) For additional information about how to obtain the latest Windows XP service pack, click the following article number to view the article in the Microsoft Knowledge Base: 322389 ( http://support.microsoft.com/kb/322389/) How to Obtain the Latest Windows XP Service Pack
Jan 30, 2013 | Computers & Internet
Tip
CONFIGURING YOUR SYSTEM FROM HOME FOR XP
For you to sit at home for your system configuration on how to setup your xp program
1. When you run the Windows XP Professional Setup program, you must provide information about how to install and configure the operating system. Thorough planning can make your installation of Windows XP Professional more efficient by helping you to avoid potential problems during installation. An understanding of the configuration options will also help to ensure that you have properly configured your system.
I won't go into that part right now but here are some of the most important things you should take into consideration when planning for your XP installation:
* Check System Requirements
* Check Hardware and Software Compatibility
* Determine Disk Partitioning Options
* Choose the Appropriate File System: FAT, FAT32, NTFS
* Decide on a Workgroup or Domain Installation
* Complete a Pre-Installation Checklist
After you made sure you can go on, start the installation process.
2. Beginning the installation process
You can install Windows XP in several methods - all are valid and good, it all depends upon your needs and your limitations.
* Manual installations usually come in 3 flavors:
* Boot from CD - No existing partition is required.
* Boot from the 6 Setup Boot Disks, then insert the CD - No existing partition is required (see the Create Setup Boot Disks for Windows XP page).
* Boot from an MS-DOS startup floppy, go to the command prompt, create a 4GB FAT32 partition with FDISK, reboot, format the C partition you've created, then go to the CD drive, go into the I386 folder, and run the WINNT.EXE command.
* Run an already installed OS, such as Windows NT 4.0 Server. From within NT 4.0 go to the I386 folder in the W2K installation CD and run the WINNT32.EXE command.
* If you want to upgrade a desktop OS such as Windows 98 into Windows 2000 Professional you can follow the same procedure as above (You cannot upgrade Windows 98 into W2K Server).
There are other non-manual installation methods, such as using an unattended file along with a uniqueness database file, using Sysprep, using RIS or even running unattended installations from within the CD itself, but we won't go into that right now.
It doesn't matter how you run the setup process, but the moment it runs - all setup methods look alike.
3. The text-based portion of the Setup program
The setup process begins loading a blue-looking text screen (not GUI). In that phase you will be asked to accept the EULA and choose a partition on which to install XP, and if that partition is new, you'll be asked to format it by using either FAT, FAT32 or NTFS.
i. Start the computer from the CD.
ii. You can press F6 if you need to install additional SCSI adapters or other mass-storage devices. If you do you will be asked to supply a floppy disk with the drivers and you CANNOT browse it (or a CD for that matter). Make sure you have one handy.
iii. If you want, you can press F2 to run the ASR sequence. For that you need a good backup created by the Windows XP backup program, and the ASR floppy disk. If you plan to install a new copy of XP - don't do anything.
iv. Setup will load all the needed files and drivers.
v. Select To Setup Windows XP Professional Now. If you want, and if you have a previous installation of XP, you can try to fix it by pressing R. If not, just press ENTER.
vi. Read and accept the licensing agreement and press F8 if you accept it.
vii. Select or create the partition on which you will install Windows XP Professional. Depending upon your existing disk configuration choose one of the following:
viii. If the hard disk is unpartitioned, you can create and size the partition on which you will install Windows XP Professional.
ix. If the hard disk is already partitioned, but has enough unpartitioned disk space, you can create an additional partition in the unpartitioned space.
x. If the hard disk already has a partition that is large enough, you can install Windows XP Professional on that partition. If the partition has an existing operating system, you will overwrite that operating system if you accept the default installation path. However, files other than the operating system files, such as program files and data files, will not be overwritten.
xi.If the hard disk has an existing partition, you can delete it to create more unpartitioned space for the new partition. Deleting an existing partition erases all data on that partition.
If you select a new partition during Setup, create and size only the partition on which you will install Windows XP Professional. After installation, use Disk Management to partition the remaining space on the hard disk.
4. Select a file system for the installation partition. After you create the partition on which you will install Windows XP Professional, you can use Setup to select the file system with which to format the partition. Windows XP Professional supports the NTFS file system in addition to the file allocation table (FAT) and FAT32 file systems. Windows Server 2003, Windows XP Professional, Windows 2000, and Windows NT are the only Microsoft operating systems that you can use to gain access to data on a local hard disk that is formatted with NTFS. If you plan to gain access to files that are on a local Windows XP Professional partition with the Microsoft Windows 95 or Windows 98 operating systems, you should format the partition with a FAT or FAT32 file system. We will use NTFS.
i. Setup will then begin copying necessary files from the installation point (CD, local I386 or network share).
ii (or if setup was run by booting from CD) the copying will probably last a few minutes, no more than 5 max.
iii. The computer will restart in graphical mode, and the installation will continue.
iv.The GUI-based portion of the Setup program
The setup process reboots and loads a GUI mode phase.
It will then begin to load device drivers based upon what it finds on your computer. You don't need to do anything at this stage.
i. Click Customize to change regional settings, if necessary.
ii. Current System Locale - Affects how programs display dates, times, currency, and numbers. Choose the locale that matches your location, for example, French (Canada).
iii.Current Keyboard Layout - Accommodates the special characters and symbols used in different languages. Your keyboard layout determines which characters appear when you press keys on the keyboard.
If you don't need to make any changes just press Next.
If you do need to make changes press Customize and add your System Locale etc.
Note for Hebrew users: Unlike W2K, it is SAFE and it is OK for you to install Hebrew language support at this phase.
To install Hebrew support:
After pressing Customize go to the Languages tab and select the "Install files for complex script and right-to-left languages".
A warning message will appear. Press Ok.
Warning: You must now press Apply!!!
Setup will copy the necessary files from the installation point.
You can now go to the Regional Options tab and select Israel in the Location drop-down list, and Hebrew in the Standards and Formats drop-down list. Click Ok.
1. Type your name and organization.
2. Type the product key.
3. Type the computer name and a password for the local Administrator account. The local Administrator account resides in the SAM of the computer, not in Active Directory. If you will be installing in a domain, you need either a pre-assigned computer name for which a domain account has been created, or the right to create a computer account within the domain.
4. Select the date, time, and time zone settings.
5. Setup will now install the networking components.
After a few seconds you will receive the Networking Settings window. BTW, if you have a NIC that is not in the HCL (see the What's the HCL? page) and XP cannot detect it, or if you don't have a NIC at all, setup will skip this step and you will immediately go to the final phase of the setup process.
Press Next to accept the Typical settings option if you have one of the following situations:
* You have a functional DHCP on your network.
* You have a computer running Internet Connection Sharing (ICS).
* You're in a workgroup environment and do not plan to have any other servers or Active Directory at all, and all other workgroup members are configured in the same manner.
on Apr 06, 2010 | Computers & Internet
After formating partition C i wanted to install a fresh copy of windows XP but after copying 9% of files into the partition, a msg appeard that some file cant b copied, and also i tried with 3 other w
This usually means that you have HDD bad sector or some kind of HDD read/write error.Boot up in DOS mode and use HDD Regenerator to check and repair your hard disk drive.This can be easily done with Hiren's Boot CD. You can download it from here. After downloading, burn ISO on a disk and try booting from CD-Drive.
Nov 16, 2011 | Microsoft Windows XP Professional
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
Windows XP won't boot
try repairinf the system with XP cd..or if it fails then format and install a fresh copy of XP...
Mar 27, 2010 | Microsoft Windows XP Professional for PC
How to format os in compaq cq40-616tu os is windows xp sp3
If you not a professional, don't worry about it.
Follow these steps;
  1. Insert the Windows XP CD in CD-ROM/ DVD-ROM etc.
  2. Boot from CD-ROM and press any key when it required.
  3. Now press enter
  4. Press F8 when it will be required.
  5. Now select the drive C for installaiton of OS XP.
  6. Now choose format option FORMAT with NTFS or FORMAT with FAT (its your own choice)
  7. Now press F
  8. After formatting the files will be installed to copy on the disk and now in the end follow the instructions to installing windows.
Good Luck
Jan 26, 2010 | Microsoft Windows XP Professional With...
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Network Boot Windows XP?
Put the HDD in any other computer , creat a folder called XPbackup and copy the XP cd to the folder, Start the XP install from the other computer  , when the install stops for CD key , turn of the computer and remove the HDD and put the HDD on the laptop and turn it on , Mostly the installation should start from where it stoped. If the Xp install askes for the source files , browse to the folder created and point to the files. Most of the time XP will install a generic HAL so no need to worry.
Mar 09, 2009 | Microsoft Windows XP Professional for PC
Installing operating system
You are getting this error because you have formatted the harddrive and now your computer cannot find your old copy of Windows.
To install the new copy you have to put the Windows disk in the CD or DVD drawer and restart the computer, when the compter starts (before the no operating system window) you should have options to Enter SetUp. You need to press the appropriate "F" key to enter set up or boot order and tell the machine to boot from the CD.
As it is now your machine is trying to start from the harddrive and its not finding anything, you need it to start from the cd drive so that it can install windows.
Aug 07, 2008 | Microsoft Windows XP Professional for PC
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
256 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
