Question about Bosch Axxis WTL 5410 Electric Dryer
Load capacity of WTL 5410
I would like to know how much is max load capacity of this dryer. I dont have the product manual to cross check. If you can help me with this info it will be great.
Thanks
    Sergeant:
  • 228 Answers
7 kg is the max this is quoted as dry load not wet halfed when wet.
Posted on Jul 22, 2009
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Dryer does not dry. Wont heat up.
I am directing you to Repair Clinic.com as that will help you diagnose the issue that you are having as there isn't enough info for me to get specific info for you!
The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160d1420640-x73616d73756e67206476353437316165702f786161/Samsung-Dv5471aep-Xaa-Model-DV5471AEPXAA-Samsung-Dryer-Parts
Good Luck!
Rich Lilja
Oct 06, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
The dryer fails to dry unless it is run for asecond cycle 2which would be usung substantial power
I assume this is an electric dryer. First, make sure you have a clear airflow path. Lint screens are not perfect, and some dryers are very prone to packing stray lint in the ductwork, especially where there are turns or changes in cross-section shape. Be sure to also check the outside vent to make sure it is not clogged.
If you have good airflow and still have problems with slow drying, check for heat. Try running one load on low heat, and another on medium heat. If on one of the cycles, the dryer never gets warm, you have a burned-out heater element. If it never gets warm, you should check for an open thermostat first, then the heaters. (High heat uses both the medium and low heaters, so you don't have to check high heat separately.)
I can't tell you what the capacity of your dryer is without the make and model (you can probably get the specifications from the manufacturer's website or user's manual). Usually, it is one full washing machine load, if the washing machine is loaded properly and the laundry is not packed in.
Oct 06, 2014 | Dryers
Ktm sx 50 auto what oil does gear box take
Thank you for contacting FixYa with your inquiry.
Capacity - Gear Oil Gear oil 0.20 Liter (0.21 qt.) Gear oil (ATF Dexron 3)
Guideline - Use only high quality 2-stroke engine oil of a well-known brand. KTM recommends Mororex products. Fully shythetic
Supplier: Motorex - Cross Power 2T
More user info on this web site: http://www.ktm.com/uploads/tx_ktmproduct/techdocs/6101L0_34254324.pdf
Let us know if you need more info.
Kind regards,
TF
Jul 02, 2011 | KTM Vulcan 2000 Motorcycles
Hi! A friend (who's just gone out of town) gave me her old Sanyo SBM-15 bread maker. Need to know if the -15 means it's capacity is 1.5 liters. Can one make bread for recipes of either 1 liter, or 1.5 in...
Hi. Sorry for the on hold problems. Maximum cups flour for baking is 3-1/4 cups. Max on dough setting is 4-1/2 cups. Max on prepackaged mixes is 2-1/4 cups. Here is a link to the owners manual. Hank<br /><br />http://us.sanyo.com/dynamic/extranet/servicers/SBM-15_OM_English.pdf<br /><br />
Aug 23, 2010 | Sanyo Kitchen Appliances - Others
Capacity
Hi there, I have the same washing machine. since it's 2002, Kenmore does not have the info.. I just called sears and they said the capacity is 3.2 Cu Feet. That translates to 19lbs of clothing.
cheers,
Joel
Aug 01, 2008 | Kenmore 43142 Front Load Washer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
182 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
