Question about GE DBSR453EBWW Electric Dryer
Is there a picture available to show where and how the front felt seal should be replaced? The old felt wasn't glued down and not in a place that I can tell where the new one should go. Thank you
I need to replace the felt of the dryer and am having a bit of trouble lifting the top of the dryer to access the drum. Any advice on how to get in there??? GE Model # DRSR495EG1WW Is there a picture of where and how the felt should be placed in a GE DBSR453 dryer? Thanks
  • 2 more comments
  • confusada5 May 31, 2009
    Hi, I think my original post ended up in the middle of another one having an issue similar to mine. I didn't have trouble getting the top or front of the dryer off. I have replaced the front bearing and 4 slides that are part of that bearing. When I opened the front panel of the dryer though, the felt seal/duct was smashed and hanging down what appeared to be the side of the drum and don't know where it came from. It does not have any adhesive on the old felt or the dryer. The only place I have found to put a new felt is on the underside of the front bearing where there appears to be a ridge/track of some sort. The felt is wider on one side than the other and does not appear to have a sewing line like I'm seen in some posts. Looking at it and the ridge/track, I put it in wide side down and thin side to the interior side of the track. There are little notches(?) that appear to hold the felt a little if placed this way.
    I tried to dry a few non-important items since I read posts of black marks but it looked like the felt was shifting and trying to work itself out and I was afraid of a fire hazard. I took it back out and did more research but can't find anywhere else that it would go or the need for adhesive for this dryer model.
    Thanks
    I wish there was an additional photo from the opposite direction that plainly showed where the piece was going. I did wonder about it being #325 but that is what the part's guy told me in the chat. I think #325 is actually a thin piece of foam between the plastic pieces. From what I can see from the picture I think I placed it right. I just hope it doesn't shift out of the track.
    Thanks!
  • confusada5 Jun 01, 2009
    No hook on either end. I've dried six loads of wash since I last put the felt in. So far no fire and no more awful squealing like a pig!
    Thank you for your help!
  • David Shaub May 11, 2010
    Put a stiff putty knife into the slot between the front & top, about 2 inches in from the sides. Push in and lift at the same time. There are spring clips that hold the top on. Do you mean 'felt' or 'belt'?
    President:
  • 2,976 Answers
Http://www.pcappliancerepair.com/model-display.php
The felt is part #12 on the drawing. It shouldn't be hard to figure the exact placement from the pictures on the site.
Posted on May 31, 2009
  • David Shaub May 31, 2009
    It should have a hook formed into the ends to hold it into place. The drum will keep it pressed in.
How do I replace the felt seal
Most felt seals are glued in with a hi temp glue. Without seeing it I can't be sure but I think the drum has to come out to fix it properly. The glue can be purchased from most parts suppliers and sometimes comes with the new seal.
Mar 30, 2015 | Kenmore 700 6972 Electric Dryer
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
Need to replace front felt seal. how do you do that?
If the front felt seal is cut or worn out there is probably some thing else wrong too so while you have it apart check the 2 supports that hold up the front of the drum from the bottom at about the 4:30 and 7:30 positions. For access to the felt: unplug the machine - Pop up the top from the front with a slot screwdriver - inside the front at the top corners there will be one screw on each side, remove them and the front will pull forward and lift of 2 hooks at the bottom - There will be wires connected to the door switch, mark and disconnect them before you pull the front away and break the switch - then you can remove the front support the big round thing, the felt is glued to the inside of this, and the supports are on the back side of this - look under the drum and see where the belt is connected to the drum- motor and tensioner, remember how it goes before you loosen it !!! Pick upward on the front of the drum and take it out of the cabinet. Put a few drops of sewing machine oil on the 2 roller supports on the backwall - spin them to make sure they are smooth and not wobbly - if they are replace them - the new seal comes with a tube of glue, remove the old one (watching how it goes back on) clean the metal and glue the new one on, check the front supports, put a few drop of oil on the belt tensioner and reassemble Cross your fingers
Nov 13, 2011 | Amana DLE330RAW Electric Dryer
Clothing keeps getting caught along the front edge of the drum, between the drum and the edge of the front opening.
The felt seals probably need replacing. It's not too difficult and they should be available at
www.appliancepartspros.com
You'll probably find if you try to lift the front of the drum that it will move up and down a bit. That's another sure sign of bad felt seals. Good luck.
Mar 14, 2010 | Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to replace the front felt seal - GE gas dryer
since you got the top opened, now look inside the front panel toward top remove screws or hex screws now you can remove the front panel. Undo the door switch wires before removing the front panel. The felt seal should be glued to the front panel aroun the opening to the drum you should be able to tell where it was.
Mar 01, 2009 | GE DVLR223 Dryers
Bosch Axiss washer front door seal replacement
Remove the top of the machine(screws are at the back).
Look down the side of the front door on the inside of the machine.
You will see a metal wire band holding the rubber on.
You usually only need a screwdriver to loosen the screw which holds it tight.
Try it out and get back to me if you get problems
good luck
Jan 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Zippers get caught in seal around dryer door and twist around and break off
I had the same problem with zippers and socks. Solution was as simple as replacing the felt seal at the top of the dryer door.The drum rides on the felt seal that has plastic guides imbedded in it. It's function is to seal and more importantly act as a guide for the drum.
Check the drum at the front edge if the gap around it is not the same or if the drum is wobbley when you lift it by hand that is probably the problem.
You will need to open the dryer cabinet. Mine had 2 catch springs at the front top edges that were released by pressing with a thin flat object that will fit between the top and bottom cabinet(butter knife). Once the top can be lifted you may find a couple of screws that secure the front panel and door. Once removed the front panel can be popped off and lifted out (careful of door switch wires).At this point you csn see the felt at the top of the door . It is glued in place and is easily removed. your local appliance part supplier can supply you with a replacement that comes with the glue and installation instructions.
Put the dryer back together and no more burnt socks and ruined zippers.
Jan 22, 2009 | Frigidaire FGQ332ES Gas Dryer
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Cylinder seal
for most dryers,
Unplug dryer
remove old felt
allow glue to set
Jun 04, 2008 | Maytag Dryers
GE DBSR453EBWW Electric Dryer Logo
1,258 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
