Question about Universal Remote Control 6-Device Universal Remote
Mtv universal control code for teac tv
Lost manual that came with control that has all codes for different brand tv's. need the code for teac
4 Suggested Answers
aprmaejun
  • 97 Answers
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Posted on Feb 22, 2009
the q guy
  • 393 Answers
SOURCE: I need the universal remote control code for the
http://www.xdiv.com/remotes/
Posted on Apr 23, 2009
Need code for my MTV universal remote for a Toshiba DVD player
If your MTV remote control is compatible, it contains the code. Use code search to find it. If a search through all codes contained in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jun 17, 2017 | Toshiba Televison & Video
Teac lcdv3253 hd tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ......
Sep 17, 2016 | Universal Televison & Video
How do I program an MTV Universal remote controller to an AWA TV. I need the code for the remote controller which is a 2006 MTV Networks remote.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Programming Notes
Mar 13, 2016 | Universal Remote Control Televison & Video
I have a teac LCD TV/DVD combo model LCDV1955 HD made in December 2008 and I cannot get a audiosonic universal remote control model JLR-6002 to work
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 02, 2015 | Universal Remote Control Televison & Video
I have a audiosonic universal remote control model JLR-6002 and need the code for a Teac LCD TV/DVD combo model LCDV1955 HD manufactured in December 2008
I need a remote code for my antsig universal remote I have a TEAC flat screen TV
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 14, 2014 | Televison & Video
Setup codes for Teac Axia
0289,0284.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Aug 23, 2014 | Teac Televison & Video
Mtv universal remote device codes
2860,2888,2849.
Aug 06, 2014 | Televison & Video
I need the code for teac sr 100 or a replacement for the remote control of teac sr 100 dock (the dock functions ok, but not the remote control)
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check the link and determine which brand remote control should be bought, and buy that brand remote control, according to availability. Codes to check with Teac brand are, 0183,0187,0188. Try this link for more details.
Nov 24, 2013 | Televison & Video
TEAC color tv model eu-80st
Different brand universal remotes have different codes. It really depends on what universal you are trying to program. In other words there is no set code for a certain model of TV. What brand and model of universal are you trying to program? Thanks for using fixya. I am here to help:)
Nov 05, 2009 | Televison & Video
Universal Remote Control 6-Device Universal Remote Logo
913 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
