Canon FAX-JX200
Problem for Canon FAX-JX200
MACHINE GIVE ERROR CODE 5100?
By rbgupta08 on May 30, 2009
MY FAX MACHINE CANON JX 201 MODEL
GIVE ERROR 5100 .
NOW WHAT I DO ?
Best Solution
posted on Aug 18, 2009
Very Helpful)
iservice
Rank: Guru  Canon Office Equipment  Expert
Rating: 89%, 231 votes
Sometimes on this error it is caused by the coded stip that determent the cartridge possition,that strip might get dirty.Wipe the plastic strip behind the cartridge with a damp cloth.That helps 80 persent of the times.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 30, 2009
Very Helpful)
rjbeg123
Rank: Guru
Rating: 95%, 826 votes
I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100. Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Canon FAX-JX200
Questions and Unsolved Problems for Canon FAX-JX200
Do you recommend Canon FAX-JX200?
Answer
Answer
Canon fax JX200 showing check code 6000. I cannot find out what it means
Answer
How to print fax recorded in new crt
Answer
i WANT TO RETRIVE FAX DOCUMENT FROM MEMORY - HOW TO DO IT?
Answer
hi, do you have the canon jx300 fax manual?
Answer
Kaip siųsti faksogramą iš FAX-JX500
Describe your Fax Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machine Experts
Top Copier & Fax Repairmen
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
