Question about IBM ThinkPad T40 2373 Notebook
My ibm thinkpad booting and hanging fault
When i press power ON button it comes on but will not boot, one of the green LED before the battery indicator LED will be ON but the LCD remain black. Sometimes when it tries to boot it hangs after working for 1 minute
  • 3 more comments
  • Anonymous Dec 20, 2007
    have tried pressing the f9 buttons at times it comes on
  • mattriv Dec 26, 2007
    Mine does the same thing, I personally think its overheating or has permanent overheating damage.
  • Anonymous Aug 11, 2008
    mine hangs on the boot, but if you plug in the ac adapter, it will boot (even if you remove the ac adapter after you get the thinkpad splash screen)
  • dasina Aug 25, 2008
    I have 2 IBM T40 ThinkPads, both having the same issues. Certainly seems like a loose connection. If I hold the laptop with 2 hands grasping the lower lefthand corner just after powering up, it will start up normally but don't bump it or move it or it will go out. I have opened up both and checked keyboard connections, mouse touch pad connections and hard drive connection. All are good. Next step, it must be some other loose connection on the mother board or in the area of the lower lefthand corner of the laptop. I was hoping to find a solution without breaking them down any further but it looks like I may have no other choice.
  • spk2 Dec 25, 2008
    Have the same problem with my T40.
    New Friend:
I have an IBM T60 and each time powered it, It powers and sounded ok and all the light are showing as well but it's take time to show on the screen a times it wouldn't show at all at the screen have try all I an but it didn't work what should I do?
Posted on Feb 25, 2013
Problem of black screen has been fixed. now I get restarted when ever I plug or unplug while laptop T42 is running
Posted on Aug 31, 2008
Try pressing Fn F7
Posted on Oct 22, 2007
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
I have a Sylvania lc370ss9 hdtv. When I turn the power on the set remains black, the power indicator flashes green and the power button will not shut it off.
The set has failed to come from standby to on fully---could be the power board but if it will not power off usually it is elsewhere.
Time to have a qualified shop take a look a get a estimate.
Dec 04, 2012 | Sylvania LC370SS9 LCD TV
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
Black screen at startup
It sounds like the graphics card or on board graphics is causing the issue, as the external monitor is not working either. Hopefully its a graphics card which can be replaced easily, or there is an expansion slot for a graphics card to be added.
One thing you could try is resetting the CMOS by removing the battery from the motherboard and leaving for ten minutes. Replace the battery and try booting.
Mar 14, 2012 | ASUS Computers & Internet
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
System won't boot - show's green battery icon only
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Jul 07, 2009 | IBM ThinkPad T42 Notebook
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
Doesn't boot up
try it pluged in without the battery, does it turn on?
when it shuts down, does the power light stay on? or is it just no display?
Jan 04, 2008 | Dell Latitude D600 Notebook
IBM ThinkPad T40 2373 Notebook Logo
610 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
