Need info. on a Tempstar Comfort 2000 unit.
I'm working on my grandma's Tempstar Comfort 2000. And I have the chip that has what I believe to be the fan relay attached to it. I need to know how I can possiby get more information on this unit, like a service manual or a better wire diagram to cofirm my theory. My grandpa went out to clean it and I believe he got water between the relay leads and the metal of the unit, because it has a big electric flash mark on it. The inside evaporator fan will come on with the thermostate, but the outside condeser fan wont. Probably a safety switch? Any assistance will be greatly appreciated.
  • 1 more comment
  • sprke23
    sprke23 May 30, 2009
    Here is the part that I have. Front and back. It is in line after the contactor.My college professor told me that he believes it the condenser fan relay. He was going off one of the leads markings that says "Fan In". I have the model #, and seriel #. If it will help. It is a 208/230, single phase, 60 Hz unit.
  • sprke23
    A local parts store gave me th # 1088977. And it cost $21.75, just for your futre information. I have it on order, but I wont get it till Wednes day. They did not have any schymatics for the unit or the part though.
  • sprke23
    sprke23 May 31, 2009
    Here are the only numbers I can find on the front: "8100", "88F", A-1 Components Corp.". And here the only ones I can find on the back: (inside a circle) "PS 3", (under the flash burn there is a number that's hard to read) I believe its - "63864A"? That is all the numbers I can find. If none of them is the right one, please instruct me where on the board I might look for it, and if there is any characters in its series that can help me in the search. Thank you for all your time and help in this matter.
This is a 2 speed condenser fan control board, the tempstar part number is
1086071, if you google tempstar 1086071 you will receive 1 listing for the part for something like 44 bucks, but if you go to sears parts direct and enter the part number they have a factory authorized substitute part number 1088977 that you can order from them for $17.49, some tempstar units were shipped without this control unit and the 2 speed fan just runs off the contactor on high speed only to do that disconnect the control unit and connect the black and orange wires that ran from contactor to the control unit previously together, and then the fan should come on in high speed when the condenser is on. there is a kit that they shipped these control units http://icpindexing.mqgroup.com/documents/086477/48201222001.pdf, (just for you to look at) so all you really need to do is get the new part from sears or run the motor in high and get rid of the part all together, hope this helps.
Posted on Sep 01, 2009
  • 1 more comment
  • jackcondtion Sep 01, 2009
    maybe to late to help questioner, however hope it helps anyone with same problem.
    to set up the high speed only. disconnect the black wire and the orange wire from the 2 speed fan control board that is pictured (the bad burnt part) and connect them together, then remove the bad part with the remaining wires (disconnect the 2 yellows from contactor and leave them with bad part) disconnect the blue from bad part (that is the low speed wire just leave it unconnected in unit) and you now have a high speed only set up. or put the new part in and connect just like the old one and you have your 2 speed setup again.
    Remember to disconnect power to unit before removing part or wires, be safe.
    President:
  • 2,559 Answers
The outside unit doesn't work off a relay,It works off a contactor that is located in the outside unit.when the unit is turned on the contactor will receive a 24 volt current which closes the contactor and turn the outside unit on,So the first thing to test is for the 24 volts at the outside unit.You could also post a picture of the part for identification.
Posted on May 30, 2009
  • Randy Hough
    Randy Hough May 30, 2009
    That is the Time/temp/defrost control board,The relay is for defrost,but will also control the fan during the defrost cycle.
    What is the part # from the board pictured and I will get you a schematic or at least some clearer pictures you can work with.
  • Randy Hough
    That may be the store part #, If you can get the number off the board,I can get some more info for you.
I have this same unit but the fan motor was replaced in Jan '09. I was not part of that but I do know that the fan motor that;s in there now is only a single speed. I had to open the unit up today because the fan was not turning. This board had nothing connected to the 'Low' output and I suspect the board was not calling for 'Hi' speed and that in itself was why the unit was failing.
Posted on Sep 04, 2009
Identify heat pump by model #
2.5 ton. Hope this is what you are needing answered
May 24, 2015 | Heating & Cooling
Gas valve clicks when furnace is running
is there a second call for a flame on during the heat cycle..it may be worn out or the signal to open is not strong enough..
Jan 08, 2014 | Honeywell Icp Heil Tempstar Furnace Spark...
Tempstar Air Conditioner wont come on
Sounds like you need a new contactor in the condenser. The low voltage is grounded. Remove the low voltage (likely 2 wires) at the condenser and wire nut the wires leading inside. With an insulated screwdriver manually push in the contactor and be sure both compressor and fan run. Then replace fuse and turn power on to air handler with a call for cooling. Obviously the outdoor unit won't run because you unhooked the low voltage but if fuse doesn't trip then it's likely the contactor. Good Luck
Apr 10, 2017 | Heating & Cooling
Fan rusting
you may need to replace it because if it is noisy like that then it might be getting ready to go up on you ... but if it is still workin then let it do its job.but you may need to start thinking about replacing it soon
Jun 27, 2010 | Heating & Cooling
I am working on a Tempstar mdl. T4H324GKA100 serial no. E062042494.The low voltage at the condenser causes the low voltage fuse to blow.I disconnected the comfort alert plug,the does fuse not blow, but the...
ohm out the reversing valve coil, ohm out all wires to eliminate shorts, change wire if needed, you have a short issue, unwire all wire and connect on at a time to find out which wire is causing the problem.
Jan 28, 2010 | Heating & Cooling
HEAT PUMP OPERATION FOR TEMPSTAR SMART COMFORT 2400, MODEL THC436AKC1. LOWEST OUTSIDE TEMPERATURE FOR OPERATION?
I have installed many heat pumps and if it is installed without and ouside temperature sensor I would not recommend running it below freezing 32 degrees farenheheit. Running a heat pump at low outside ambient temps. can hurt your compressor and that is the most expensive part of the outside unit.
Dec 20, 2009 | Heating & Cooling
Heating & Cooling Logo
1,775 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
