Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
My Canon Imagerunner 2200 won't scan.
I put the document I want scanned in the feeder, push the scan button and then "online" on the screen and it says "waiting..." for the last 10 minutes.  What am I doing wrong???
  • sfourez Jul 20, 2008
    I can get it to scan into a word document,but I need it to be in a pdf. Does anyone know how to get it to pdf? When I open my Adobe Reader I don't have an import option or anything??
    Thanks
  • Anonymous Jan 13, 2009
    when i use this tools Canon Network scangear scanning start but after 98% gois to hang. can u solve the problem?
  • 3 Answers
Sorry that was actually me...after i posted...it asked me to register...so i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner online...open up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Posted on Nov 22, 2007
Download and use the 2.20 version of network scan gear
http://www.usa.canon.com/html/download/canonnetutils.html
Hope it helps
Posted on Jan 23, 2009
Is your printer/scanner hooked up to the network? I have the same problem and discovered it didn't have a network link. That's the next step... I don't know if there is any configuration to be done after that.
Posted on Nov 06, 2007
SOURCE:
How do I scan on the Canon imageRUNNER 3300
instalation of photocopier/scanner with pc model no IR-3300. Kindly tell me the procedure to install it and make it functioning...
Mar 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
I have a problem with the error e 051 some body help me
000 Fuser problem E010 Main motor, motor board, clock pulse E030 Counter E050 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E204 Document sensor, scan reverse sensor or scale E210 Lens problem E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
Jan 15, 2010 | Canon imageRUNNER 400S Copier
Unable to scan document
try to add your printer so that you can scan, just click start of your computer then go to all program the add printer or scansoft then restart your pc to take effect
Jun 30, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Dec 12, 2008 | Canon imageRUNNER 2200
Scanning from Canon image runner 2200
You may have to upgrade your adobe
Jul 20, 2008 | Canon imageRUNNER 2200
Scan Function Error
when you open the tool did you use discover or select ip adress unless the tool selecs the scanner it wont work what program are you scanning with scan tool is only a driver you also have to select scan gear tool as your scanner in your program
Feb 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Scanning
you will need to download and install color network scangear.http://www.usa.canon.com/html/download/canonnetutils.html
the document will show up as a image, and cannot be edited. you will set the document in the feeder,place it online and then pull it over from your pc. you need office xp or higher.
or you can by universal send and scan to email, scan to a flle. Both as pdf and jpeg/tiff . this will cost a lot more and may not be worth it with a older model. if you need more help installing scangear reply back
Dec 11, 2007 | Canon imageRUNNER C3200 Color Printer
Computers & Internet Logo
3,223 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
old marine
old marine
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
