Question about Sony Televison & Video
While reconnecting wires to the circuitboard after an internal dust cleaning, I discovered that the connector with 1 white wire and 1 black wire (coming down from the wiring harness which wraps around
On my KV-2197 PF TV I unplugged the connector (with one black and one white wire)that runs from the picture tube down to a location in the back left of the circuit board. The pins are numbered "1" and "2." The problem is that the plug could plug either way and has no identification on it. Which pin gets the white? and which pin gets the black?
  • bideshigreg May 30, 2009
    Wow! Your fast! Thanks a million!
    BG
    President:
  • 2,559 Answers
Black= 1
white = 2
Posted on May 30, 2009
No sound
Posted on Oct 11, 2010
I have a 96 ford explorer xlt with a hidden hitch. the 7 pin rv connector is not working. i found where the wires from vehicle connect to 7 pin connector and one wire was caroded at the crimp black wire...
Yes, you need the other wires to provide the trailer with battery voltage. If the trailer has trailer brakes, you should have an RV mechanic wire up the connector so the brakes on the trailer operate from the Ford.
Mar 11, 2011 | Ford Explorer Cars & Trucks
Audio protect off
hi,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} All of a sudden it showed PROTECT nomatter how many times you turned it on and off.
Checking the speaker cabling for any shortcuts and eventually disconnecting all cables did not solve the problem.
So you opened the case and disconnected the pcb where the speaker outputconnectors are soldered to. This small board also had the speaker on/off relais (light blue). you should disconnected the main connector (white) from the main pcb and turned the amplifier on again: problem of 'protect; will be solved ....
So you should checked for short cuts in the pcb, removed the dust and made sure the wires (red black black white) were not touching eachother; the isolation can be damaged by the internal heat and the wires are routed so that they touch internal components.
After reconnecting the main connector the receiver should be okay...
May 26, 2010 | Philips MX5100VR System
To reconnect the 2 jumper wires in my Acer internal wifi card.
on the internal wifi card u might find a slot marked as main and auxillary.the white cable goes to the main slot and the black cable goes to the auxillaryu slot,,best of luck
May 13, 2009 | Computers & Internet
I cut the plastic wiring connector, fan motor to to light kit, from a Harbor Breeze paddle fan. This connector had a short in it, and I wanted to hard wire around this connector. I reconnected all of the...
The top wires, black, white, and green are the ones to hook to just run the fan. The blue wire is wired with the black at the top if you want the lights to work. At the light kit, the blue and white wires power the lights.
Apr 21, 2009 | Electrical Supplies
Relay is clicking from the circuitboard(12v-832a-1cs-s)
When you unplug the unit, the compressor needs to equalize the pressure inside before it can be plugged back in. If you plug it beack in too soon, the compressor will not start untill this pressure is equalized. Sometimes compressors get harder and harder to start as they get older and it gets harder for the start relay to start the compressor. I am not a electronics tech but it may be that the compressor is just hard to start and my need a hardstart kit.
Nov 11, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Installing universal Oxygen sensor
here is the 97 civic electrical diagrams. after you download and unzip the file, try 17252.pdf.
Oct 11, 2008 | 1996 Honda Civic
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Thermador MBY microwave
The problem is the push-on connector on the UPPER door-latch switch; if the white plastic around this connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blade on the switch before reconnecting as the heat has likely left a burnt coating.
Mar 10, 2008 | Thermador MBYB Microwave Oven
Televison & Video Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
