Question about GE WDSR2080D Top Load Washer
GE washer WWSR3090T6WW
Recently replaced nylon coupling that mounts agitator to machine. It stripped bolt backed out and the agi. came off. Simple repair, but new bolt seems to be backing out again. How do remove agitator? Easy to remove softener cup but past that will require some knowledge as to procedure so as not to damage parts. Need to get into agitator to examine the mounting couple and bolt. How? Also why would the bolt continue to back itself out.
Is there some other problem thnat is causing this that needs to be addressed? GE washer model WWSR3090T6WW top load.
  • 1 more comment
  • Anthony k Nov 17, 2008
    softner cap removed... where i was expecting to see a bolt underneath i saw another solid piece of plastic... is this the type of ge that needs to "pop" off... no bolt to remove? my ge top load wont spin or agitate... belt wont grab anything turning clockwise.. but will turn the drum when spun counterclockwise... thought my problem might be the coupler or timer?? any suggestions woulld be great...
  • bedroski Feb 23, 2009
    The agitator doesn't work in the wash cycle and can not remove the agitator, please help.
  • snapper21joh Feb 26, 2009
    removed cap from top of agitator. now, how do i get agitator off since there are no screws only plastic?
Posted on Oct 14, 2008
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
Won't agitat under agitator yellow coupling held by 7/16 bolt should this spin freely or does this mean its stripped
it probably means that it's stripped. it grips the spine and allows movement of the agitator. the transmission shaft may be rotating back and forth, but the agitator doesnt move properly. i would remove the coupling and take a look underneath it to see if it's stripped.
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
Load whirring and banging noice whe machine is put on cycle or spin. Basically the drum is not working.
your agitator coupling underneath the agitator is stripped out,you need to remove the dispenser on top of the agitator then theres a 7/16" bolt down inside there to remove and the agitator can be lifted out to replace the coupler underneath
Dec 22, 2010 | GE WBSR3140DW Top Load Washer
Washer will spin but does not agitate, checked the belt its ok.
Number 310 probably is stripped out. Mounted under the agitator this is called a drive block/bell.d390837.jpgI believe the part comes with a new bolt also. This plastic piece has splines inside that slip onto the tranny. Over time the splines wear smooth and the washer will not agitate. To get to it you yank off the agitator:
Oct 28, 2010 | GE WDSR2080D Top Load Washer
Agitator loose does not swish clothes around .... can't figure out how to remove the agitator in order to see what may have come loosened or if splines are stripped .... how do you remove the agitator ?
Hello, on the style GE washer there is an agitator coupling under the agitator that will sometimes strip out. To repair this remove the agitator by pulling it straight up and out.
TIP: If you can't get your fingers under the agitator, you can slip a belt under the agitator and then pull by that, once the agitator is off you should see a yellow coupling held on by a 7/16 bolt, remove that bolt and pull the coupling up and off the transmission shaft. Sometimes it will be hard to remove and you might need to knock it up with a hammer. Once it is off you should be able to slide the new one back on, bolt it down and push the agitator back on.
Jun 14, 2010 | GE WBSR3140DW Top Load Washer
I have something stuck under the adjatator. How
Hi, depending how old you GE washer is will determine how difficult the agitator will be to remove. However, all GE made ( hotpoint, baycrest, some kenmore, moffat, mcClary, etc. ) washer's of the past 50 yrs. or so have agitator's that are pressed onto a drive block and need to be pulled off, sometime's by hand, sometimes by a greater force, i.e. "agi-tamer" or "hammer". ( of course the hammer method will require you to by a new agitator ). The "agi-tamer is a real tool which slides under the agitator and by way of being pressurized with "cold" water ( hot will burst it ) will push the agitator up off the spline/block...don't stand over it looking down or you'll potentially get "knocked out" ha ha ! Hope that help's. At least you know it does "pull off" and it isn't bolted in place. Good luck, macmarkus :)
Feb 16, 2010 | GE Washing Machines
Washing machine wont agitate
yes its belt.he is very correct.but many other possibilities check that also ----------- It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Drive motor
Drive pulleys
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Sep 02, 2009 | GE Profile Performance WPSF4170WAA
Washer doesnt agitate but spins and drains. how
Agitator pulls straight up and off. (you may have to slip a belt under it to pull it..... a hard yank) Drive coupler is nylon part you will now see, held on by one bolt. Remove bolt and pull off. If it won't come off, just break it apart with a chisel, as you need to replace that part anyway.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Jan 11, 2009 | General Electric WHDSR316G Top Load Washer
Your problem is the agitator coupling is stripped. Very common on your washer. Just pull up from the base of the agitator to release it. Lip your fingers under the bottom and work it from side to side while pulling up. The coupling is the brown plastic piece attached to the transmission shaft. Remove the bolt and oring. If that bolt is rusty or oring damaged get a new one with the new coupling. Sometimes the coupler is real stuck on the shaft. Becareful not to damage the transmission shaft or the threads for the bolt to hold the coupler if you use a gear puller.
Nov 24, 2007 | GE WJSR2070B Top Load Washer
GE WDSR2080D Top Load Washer Logo
686 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
