When trying to choose an option it keeps scrolling all the way down to the last option. if u try to go up and just takes u back down again. Same here. I am also having odd PS button issues with my main controller, a DS3. Thinking the controller was sending a bad signal, I unplugged it's battery, but the original SIXAXIS still locks the system into a downward/rightward scroll. The BT remote does not have this problem.
I have face the the same problem with my ps2 conttroler. In my case it was the problem with the analog (the sticks). May be the spring of your left analog is broken is broken. Do not try to open it yourself and fix, it can disturb the wiring of the remote. Take it to your local ps repair shop or you will have to buy a new one
Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
