Question about Sony KDS55A2000 55" HDTV
XL 5200 bulb replace and NO Picture or Sound
I just replaced my SONY XL-5200 with BRAND NEW one straight from Sony Retailer. Placed new lamp in, closed & Secured INNER door with latch & screw tightener then outer door as well. My KDS-50A2000 fans come on but NO picture or sound. Green Power light blinks constantly for a few minutes then LAMP light blinks 3 times. I tried depressing the door switch a few times to assure it's not stuck to no avail...PLEASE HELP ! *Can the brand new lamp be bad? This was the WHOLE unit, I did not just replace the bulb.
  • JerZ ICE May 30, 2009
    I Triple & Quadruple checked the door and it is seated fine. I've unplugged the TV pulled the lamp out and re-installed as per the direction sheet 20 times still to no avail. I turn it on and the Green power light flashes immediately, both fans go on and approx. 7 seconds later the lamp one kicks down to a slower pace as normal operation. Then about 90 seconds later the red lamp light comes on and blinks but it's a STEADY blink not in a pattern of 3 or 4 as I stated before, I watched it and it's STEADY. I even blew out all the dust with an air hose cause I seen someone else's post about that and still no go :(
    YES Old lamp finally died 2 days ago after a month of the Lamp LIFE WARNING showing on the screen which kept getting duller and less vivid.
  • 10,594 Answers
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
Posted on May 30, 2009
  • Shahid Electronics
    Shahid Electronics May 30, 2009
    OK, if red light is steady / continues blink then it is either lamp or ballast supply issue.
    Was old lamp broken so you replaced it?
    Right, Please check new lamp in another Sony TV or Sony retailer there you bought it and in worst case ballast supply can be bad too.
My lamp is blinking red. I read that I should replace it with an XL-5200 lamp.
PN# for Lamp to Sony KDS50A3000 XL-5200
Mats has them for $129.95 1-800-628-1118
Look on EBay I have found Lamps for $85.00
Jul 24, 2011 | Sony KDS-50A3000 TV
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
No picture and red light flashing please help
You need a Sony XL-5200 replacement lamp. Flashing red light indicates lamp needs replacement.
Sep 04, 2009 | Sony KDS-50A2020 Television
Picture and sound go off for a few seconds and then come back on.
When the bulb goes off with the sound. The lamp is starting to fail and you need to replace it. Wear gloves when replacing the lamp. Use XL-2400(part # F93087500) replacement lamp. For information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Putthe new lamp in its place. Mount it securely and take extra care not totouch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Dispose the used lamp properly. It contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 23, 2009 | Sony Televison & Video
XL 5200 bulb replace and tv still down
3 blinks means the lamp cover door is nit properly attached. Remove the lamp door and reinstall it
May 28, 2009 | Sony KDS55A2000 55" HDTV
My tv does not switch on.
Thanks for update.
TV requires New Lamp XL-5200 and lamp replacement procedure is very easy, mentioned in user manual.
Click Sony Support to download user manual online free copy.
You can buy XL-5200 Lamp from Sony Accessories Store for $250
Please do not buy aftermarket or compatible lamp.
Mar 28, 2009 | Sony Televison & Video
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replacement lamp
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Dec 12, 2007 | Sony XL-2000U Projector Lamp for XBR800...
Sony KDS55A2000 55" HDTV Logo
908 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
