Question about ButtKicker LFE Kit Subwoofer
No kick The kicker is not "kicking" and I can't figure out why. Thought it might be sw cable. Tried a new one and that didn't work. Tech support at Guitammer said green light on amp means it is getting power and a signal from line level input. Well...it's green even when there is nothing connected to line level input. I've checked all connections, cables even sub out to regular subwoofer so I know there is a signal going out. Thinking the amp must be messed up but the green light has me wondering. Any ideas?
    Sergeant:
  • 233 Answers
It can only be a few things...either it overheated and is in a protection mode...the amp went out... the input line is not supplying input...or the output line is not supplying output. If the input is good...the output that goes from the amp to the kicker itself may have came unplugged. If that is not the case, it may have overheated.
Posted on May 30, 2009
  • frank_crab May 30, 2009
My 1996 Toyota Camry's back-up lights are out, bulbs are fine. A blown fuse? The driver's manual directs me to the passenger side kick panel. Where do I find this and how do I remove it to get
Look on the shift linkage,shift cable or the transaxle,
for a back up switch
Call or stop by a dealer & walk in the back service bay,
from the outside & ask a tech were the sw is
Jun 12, 2012 | 1996 Toyota Camry
I had just recieved a brand new DM6. Upon setup the kick drum didin't seem to be working. I switched the cable going into the kick drum pad with the Tom 3 cable and the pad was responsive. When I...
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELE
THAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
Jan 12, 2011 | Alesis DM6 Electronic Drum Set
How to install kickstart case cover and gear assembly on 69 flh 4 speed ratchet top transmision
If all you want to do is install a the kick start case cover, drain the transmision fluid and just take the old one off along with the kicker lever intact. You'll need to look inside and see the relationship of the kicker gear stop and the kick starter lever. Then, once you see how it's supposed to look, ie. the kicker straight up and the kicker gear stop at the X o'clock positon, start taking the stuff apart. Transfer all the old parts to the new kicker cover. Align the kicker gear properly with the kicker lever. When you install the old shaft into the new cover, make sure you put a new seal in between the two bushings so it doesn't leak. Put the new cover with the rest of the kicker parts in it back on the transmission and refill the transmission with lube. 20-24 ounces.
If the clutch gear on the end of the mainshaft needs to be replaced, it's advisable to have the special puller to get it off with. If you don't have the puller, you can put some pressure on the clutch gear like you're trying to pry it off and rap on it with a hammer. Hit the side of the gear not the end of the shaft. Don't hit it hard enough to break anything, just a good tap should pop it off. If not, you'll have to find someone with a puller or buy one.
good Luck
steve
Oct 01, 2010 | Harley Davidson XLH 1000 Sportster...
Xs400 and i havent started it in a month and a bit. I tried starting it today and the engine went to turn over but couldn't then i heard clicking coming from the solenoid (hitachi a104-70 My lights were...
Battery is most likely - they drain fairly quickly when sitting and the electric start will kill one in 15-20 failed starts. Pull it, put it on a charger overnight, put it back in and try it again. Does it start with the kicker (assuming you have one)?
Jul 11, 2010 | 1982 Yamaha XS 400
Shes a ***** to start
Assuming the bike runs well and this is just a kicking technique problem.
push the kick starter slowly until you get to the hard spot(TDC), pull the decomp lever, and push the kicker a little to get past top dead centre, then release decomp and give it a decent kick, should never kick back
Apr 14, 2010 | 2003 Husaberg Fe 400 E
Furnace won't kick in when thermosat is turned up. Was able to get furnace going by jumping wire on control valve , but it has kicked out in the middle of the night. Had a tech over to look at it and he...
If this is a High Eff. Furnace, sounds like the pressure switch is holding furnace out. Check to make sure Intake vent is not plugged. Make sure
that the exhaust vent is not getting backpressure from
windy outdorr conditions.
Jan 08, 2010 | Heating & Cooling
77 fxe kicker slams back when started and the clutch is pulled in . replaced thrust bearing and the kicker gear stop was snapped off.. replaced and re assembled per shop manuel..?
all kick starter kicks back when starting just give it a little keck like just push dawn on the kick starter to wear it just turnes over 1once than jump on it than it should fire without kicking back but kick it hard or it will kick back
Dec 05, 2009 | Harley Davidson FXD Dyna Super Glide...
49cc scooterwont kick star the kicker makes a grindin noise
You could take out the kicker to inspect for damage or wearing. The grinding noise could be due to oil level that's too low, or its recoil spring out. If you have the manual to guide, revove the kicker side-cover and inspect for any damage.
Take out the starter-motor and have it inspected at a fine parts/repair store.
Nov 13, 2009 | 1985 Suzuki GSX-R 750 F
Amp protection
Does it go into protect if you disconnect the speaker wires from the speaker terminals of the amp?
Feb 16, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
ButtKicker  LFE Kit Subwoofer Logo
219 people viewed this question
Top ButtKicker Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ButtKicker Audio Player and Recorder Expert? Answer questions, earn points and help others
