Dell E-1705 Motherboard Replacement
I had Dell replace my motherboard because the power jack broke off the circuit board.  Since the replacement, the computer runs sluggishly and many of the components no longer work or are accessible via Windows (I have Windows XP Pro).  Instead of replacing the replacement refurbished motherboard, Dell wants me to back up the data and reinstall Windows but my CD drive won't record data so I may be relegated to purchasing external storage via the USB port (which also may not function).  Is this a Windows issue or a hardware issue?
  • 2 more comments
  • Allan Alan Oct 24, 2007
    That was the first place I checked and the first place Dell suggested I look.  The problem is much more complex and is either a defective motherboard or the possibility that by substituting a replacement "refurbished" motherboard, the operating system thinks I have a new machine and is trying to prevent a violation of the license agreement by disabling certain asects of the operating system.
    I do not see an "activation wizard" at Syatem Tools in Accessories at Programs.  Perhaps you could be more precise.
    there is no "activate Windows" in Windows XP Pro that I see under system tools
    Maybe that's the problem - perhaps changing the motherboard de-activated certains parts of Windows such as the availability of that command
  • 196 Answers
Start by checking ControlPanel/System/Hardware/Device Manager. Look for yellow marks that indicate devices not installed properly. This is usually a driver issue, and Dell should have given you a disk with the drivers you need.
Are you getting any error messages?
Posted on Oct 24, 2007
  • 2 more comments
  • Hugh Vandervoort
    Hugh Vandervoort Oct 24, 2007
    What makes you think this is an activation issue?
    There is usually an activation wizard accompanying this procedure. It's not uncommon to have to do this.
    If this is the problem, go to Start/Programs/Accessories/System Tools and run  the activation wizard, which should give you a phone number to call and complete the process, which  is usually quick and painless. If that doesn't resolve the issue, go back to Dell for a new board, or just follow their instructions to re-install the operating system.
    Eternal USB drives are an excellent idea, by the way. I have one for each of my machines, and they provide quick and reliable backups.
  • Hugh Vandervoort
    It's labeled "Activate Windows".
  • Hugh Vandervoort
    That's weird. It's in XP home and pro as far as I know.
    Copy and paste this command into a run box:
    %SYSTEMROOT%\system32\oobe
    \msoobe.exe /A
    According to MS:
    How to activate Windows XP by using the Internet
    loadTOCNode(2, 'summary');
    To activate Windows XP by using an Internet connection, follow these steps:
    1.
    Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Seehttp://support.microsoft.com/default.asp...
    for more.
  • Hugh Vandervoort
    Changing the board should have no effect on Windows, especially as you say there are no missing drivers.
    I would try a reinstall at this point, after transferring the data to some other medium such as a USB drive or even a flash drive.
    You could also try a repair install:
    http://www.microsoft.com/windowsxp/using...
    This procedure should preserve your data.
Mini dell 910, no power
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-dell-inspiron-mini-910-30w-ac-adapter-19v.html
Nov 21, 2012 | Computers & Internet
Charging light wont come on
A) AC adapter (Charger) is bad.
Use a multimeter, and check it out.
[ DC Voltage.
Test plug of cable that plugs into laptop.
Positive (Red) probe lead of multimeter, to Center Hole of plug on AC adapter.
Negative (Black) probe lead touches outside cylindrical metal shell.
You should read close to 19.5 Volts (DC) ]
AC adapter checks out OK?
B) DC Power Jack is bad
[The DC Power Jack is the port on the laptop, that the AC adapter plugs into. On laptop may be marked DC_IN ]
Damage to DC Power Jack prevents laptop from charging, or running strictly off of the AC adapter.
Battery removed take a No.2 pencil's eraser, and see if you can gently move the Center Pin, of the DC Power Jack.
ANY perceptible movement means replacement of the DC Power Jack.
The pin itself may not move, and the entire jack moves.
The good news is the DC Power Jack is not soldered to the motherboard.
It is soldered to a separate, therefore replaceable, small circuit board,
http://www.parts-people.com/index.php?action=item&id=3698
Click to enlarge. In the photo the DC Power Jack is at the back on the right.
This is is what the DC Power Jack, looks like not installed on that small circuit board,
http://www.elept.com/dc-power-jack-for-dell-inspiron-xps-m140-m1710-m1210-m2010_p2971.html
Looking at the view on the right, note the pins sticking out.
You are looking at the back view, and the jack is laying on it's side.
The pins go through the laptop's motherboard, and are soldered to the motherboard.
Where the pins are soldered to the motherboard is a solder connection. Commonly referred to as a Solder Joint.
Plugging in, and missing the hole of the jack, can cause the AC adapter plug to damage the DC Power Jack, by bumping into it.
Bumping into the plug of the AC adapter, while plugged into the DC Power jack, can cause damage to the jack.
Can cause cracking of the above mentioned solder joints. This leads to an intermittent contact, and eventually no contact, of the DC Power Jack TO the motherboard.
In this case the solder joints are just re-soldered.
Damage to the body of the jack itself means replacement of the DC Power Jack, or replacement of the USB/DC Power Jack circuit board, itself.
(Unless you, or an acquaintance can un-solder, and solder real well, the option may be to just replace the USB/DC Power Jack circuit board)
DC Power Jack proves to be OK?
Problem is one, or more Power MOSFETs on the motherboard.
These determine if the Battery needs a trickle charge, or a full charge, or no charge at all.
Also determines if the laptop is to just run off of the AC adapter, and not the Battery.
This example is for HP Pavilion dv6000 and Pavilion dv9000 series of Notebook PC's. You can use it for cross-reference information.
(Location of the Power MOSFETs on your laptop's motherboard. General idea of what they look like ),
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
What? Looks like motherboard replacement to you?
OK
Let's price a Fairchild Semiconductor International - FDS6679 - Power MOSFET,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
If you buy one the cost is $1.01 USD
Look to see if the Power MOSFET/s are burned. Blackened, bubbled, or blistered.
There is one more small component, that if bad will produce the same results;
Ceramic Capacitors.
Look back at the Mayohardware blog. Look at the second photo down with the AO4407 Power MOSFET circled in Yellow.
Note the small rectangular shape to the immediate right, that has the wide dark band on it. There is one above it, one above that, and one to the right of the top one.
See if any of these, (No matter what the size. Look at all of them), are burned. Blackened, bubbled, or blistered.
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wquyZ1z0t6fg
NOT stating these are ones to use. Just showing average cost.
.42 to .76 cents USD. Approximately a half dollar to three-quarters of a dollar.
Motherboard?
Average example,
http://www.amazon.com/Dell-Inspiron-M140-Motherboard-HC425/dp/B001155N0U
$200 USD
Average example of the -> package type of the Power MOSFETs used,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
http://www.youtube.com/watch?v=5uiroWBkdFY&feature=fvwrel
You don't need a Soldering Station. A low Wattage soldering iron, and that tip.
http://support.dell.com/support/edocs/systems/xps140M/en/sm/index.htm
Regards,
joecoolvette
Oct 08, 2012 | Dell Inspiron XPS M140 Notebook
The inside power plug for Toshiba laptop is broke. The estimated cost for replacing the plug is $300.
Or, for $399, you can go to Walmart and get a new Toshiba laptop.
The reason it costs so much is the labor involved. To repair this break, it literally requires a complete disassembly of the laptop, replacing and soldering on the connector, then reassembling the laptop. Laptops, unlike desktops, were not made for easy service, due to the fact that they're trying to pack 10 pounds of stuff in a 2 pound box, for lack of a better analogy.
It's a lot of work to fix it.
Jul 06, 2011 | Toshiba Computers & Internet
Where the charger plugs into the laptop the pin broke off from the laptop can I replace just that piece
the power on a Dell laptop is an integral part of the Motherboard so I am afraid it needs the whole motherboard replacing.
Dec 19, 2010 | Dell (8N816) Motherboard
Ac power jack not seeing power cord inspiron 6400 when I plug in ac - the light does not light to show ac power and because it is dead I can't turn it on.
YOu are having issue with the motherboard. ther might be a short circuit or bad part on the motherboard that might have caused it not to detect the ac adapter and system will not power on. You need to have motherboard replacement.YOu can contact dell for repair options.
Jul 25, 2010 | Dell Inspiron 6400 Notebook
Dell Inspiron B130 - can you replace the connection for the power source/battery charger? Mine is shorting out and not always charging the battery (new battery, new AC cord and adaptor).
Yes you can replace the power adaptor. You may also remove the solder from the existing adapter and re-solder it back on which is what I did. If you just want to replace it I suggest Ebay before I repaired mine I ordered a new one for $5 w/ free shipping.
Dec 29, 2009 | Dell Inspiron B130 Notebook
Power Jack replacement
Generally, this a not a process that can be done by most people, you need to be a good circuit board soldering specialist.
The Jacks for most motherboards can be found on EBay and several places advertise there to replace the Jack on your MB for $100.
In most cases, for the same price, maybe less, you can buy a replacement motherboard.
Dec 27, 2009 | Computers & Internet
Dell Inspiron 5150 power jack is bad
Contact www.e-techsiliconvalley.com
They are laptop repair expert. Give my name (Farhang) as reference and ask for help.
Dec 01, 2008 | Dell Inspiron 5150 Notebook
DELL d600 model pp01l
If your motherboard traces are damaged, I would highly recommend replace the board. This model laptop can have considerably high current running through that jack and traces. if anything is weak it will burn through.
Or take it to a electronics specialist.
Oct 11, 2008 | Dell C600 (002UH) Motherboard
Dell Inspiron 1200 Charging Problem
Was the battery a Dell replacement? or was it a Chinese replacement battery?
Your charging circuit may have been damaged.
Oct 09, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Computers & Internet Logo
535 people viewed this question
Alun Cox
David Payne
David Payne
