Question about 3M ? Headlight Lens Restoration System # 02516
How many gallons of compressed air will I need to clean 1 pair of headlights with 3M Pnuematic Headlight Restore System?
How many gallons of compressed air will I need to work on one pair of headlights using the 3M Headlight Lens Restoration System?
    Sergeant:
  • 384 Answers
73 seankim,
You will need to get an Air Compressor. I assume it will take 100's (if not 1,000's) of gallons of compress air. Actual amount depends on how long you run the polishing tool.
Posted on Jun 02, 2009
How to improve dim yellowy head light CPI oliver 2007 50 cc
Use 3m headlight restore kit. I find that one to do the best job
Dec 31, 2015 | Cars & Trucks
How do i install the welts on the front light assembly of my 1994 jeep grand cherokee laredo?
If by "welts" you mean some kind of plastic or rubber trim, clean area with 3M adhesive cleaner, then use 3M Black weather strip adhesive.
Dec 10, 2014 | 1994 Jeep Grand Cherokee
How to clean your headlight covers
Try a buffer to your lights with some 3M heavy cut compound
Jun 06, 2012 | 2002 Chrysler PT Cruiser
1998 camry headlights are too dim at night. Any repair to clean old lens or buy brighter bulbs
I haven't tried that one, but I have used the Permatex kit to polish plastic headlight lenses. All auto-parts stores carry it. It contains everything you need, and good instructions. It doesn't make them quite like-new, but it works pretty darn well. The 3M is probably pretty similar. It should have several grades of very fine wet-sanding paper and a polishing paste. You don't need a large quantity of the paper or the paste. I would be wary of using any power tools, since you could easily get the plastic lens warm enough to soften it. Good luck, Al K
Nov 22, 2010 | 3M Automotive ( 02516) Headlight Lens...
I have dirty headlight covers and want to remove them to see if they can be cleaned. I have a 2001 Impala
Novus products worked for me. There are three strengths. No. 1 is a general
spray cleaner. No. 2 is a fine scratch remover that requires some elbow grease.
I find rinsing it as I work it in helps speed up the process. The yellowing and
small scratches are caused by ozone and sand blowing in the air. This product
won't make it factory new but it will give a much better cleaning than any other
product I've found. I've saved many friend's the expense of changing their
headlights.
Don't use windex or dishsoap on headlight plastic. They have ammonia in them
and causes microsopic pitting and fractures in clear plastic.
I bought my Novus products on line, saved gas running around trying to find it.
Jun 18, 2010 | 2000 Chevrolet Impala
Headlight lense foggy want to clean them
auto zone sells a lens cleanig kit to do that
Nov 17, 2009 | 1996 Plymouth Voyager
Headlight lenses on my 2004 elantra are fogged up and cannot seem to get it off what do we do?
You'll need the following. Painter's tape or Masking tape, 2000, 2500, 3000 grit sandpaper, bucket of water, headlight polish (PlastX, etc) and microfiber cloths
Mask off around the light so you don't have to worry about sanding your paint if your hand slips.
Soak the sand papers for at least 15 minutes. The more water the better Using the lowest grit, start sanding in ONE DIRECTION ONLY,(side to side). Keep the sandpaper wet and dip it in your bucket of water frequently. Now dry the headlight and it should look all hazy
Switch to the next finer grit, and repeat the step above, but this time go in the OPPOSITE DIRECTION (up and down). Keep using water
Dry it again, and it will look better than the first time.
Repeat the process again with your finest grit. Again, OPPOSITE DIRECTION with plenty of water. Dry it off. It should look relatively new at this point. Remove the tape as it will contain bits of grit from the sandpaper.
Generously apply the headlight polish in a circular motion to the headlight
Using your microfiber cloth, rub off .. repeat several times with FRESH rags until the polish is dry and gone.
Now the headlight will look like new
Nov 05, 2009 | 2004 Hyundai Elantra
Headlight lens problem
plasik-magic sold at plastic suppliers
May 25, 2009 | 1999 Dodge Stratus
Need to clean the inside of the headlight fixture
How did the inside get scratched? Never seen it before. You can resurface the outside of lights with the 3M sanding kit. About $400 for the kit or find a shop that does around $130 for the pair
Mar 27, 2009 | 2001 Mitsubishi Eclipse
3M  ? Headlight Lens Restoration System # 02516 Logo
138 people viewed this question
Top 3M Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a 3M Tool and Hardware - Other Expert? Answer questions, earn points and help others
