Question about Network Engines, Inc. (SYS-NEI100-000) Firewall
How do you disable engine immobiliser
I need to know how to disable my engine immobolizor because it has immobolized my car and we think it is faulty, I have no power in my car other than my radio works
  • paulabur May 30, 2009
    Hi there ArcAiN6 thanks for your help my car is a Ford Fairlane 1986 model sedan auto it has a paralyser 375 cyclops and was installed 2001 the person we got the car from lost his remote so the raa made it easy for him to start his car with the button under the dash, recently we have had it rewired and out driving yesterday it just died no power only the radio was working and the botton under the dash I tried it and it is not the battery as the button tried to start the car but to no go, we used to have the red light flashing in the car but now no power at all and we had to be towed home yesterday ... :>(
    Novelist:
  • 152 Answers
If my understanding is correct, the immobilizer interrupts the power from the ingition system / switch to the rest of the vehicle. In order to disable / remove this you will need to find the model of the device, and any installation information / manuals for your model, then see if there is a way to disable it, or remove it completely from the system.
Without the particulars such as car make / model / year / engine type
or device model number / manufacturer, i cannot make any further assumptions
Posted on May 30, 2009
  • Chris May
    Chris May May 30, 2009
    I cannot seem to find a product installation manual online.
    My suggestion is to have the person that re-wired the system, or a qualified technician remove the device completely.
    It is possible to remove the device, and replace the wiring harnesses with stock, I'm not sure on a price range here, but it should not be too expensive.
Help do you know where the immobolizer is thanks
Make and model would help. Most vehicles have the immobiliser as part of the(ECM) computer program.
Apr 28, 2015 | Cars & Trucks
How to reset the immobiliser
Never reset the immobilizer. Once you reset the immobolizer, it will produce a 96 character seed code, which requires seed code calculator and a long way to put it back to work. Simply go to add key function.
Mar 31, 2015 | 1998 Toyota Corolla
Disable immobiliser
the immobiliser block the engine because the sysytem dont reconice the key fob try other key
Sep 09, 2014 | 1995 Audi A4 1.8
Car has immobiliser fault, want to disable immobiliser, what colour is the wire to immobiliser
If this immobilizer is a factory system, I don't think you can cut the wire and disable it. I think the computer will recognize it's disconnected and activate automatically.
Nov 10, 2013 | Isuzu Trooper Cars & Trucks
Car won't start , said it was disabled for
THe key has a code in it that is read by the engine immobiliser. BY removing the key and reinserting you are giving the immobiliser a chance to read the code again. Give it a try. THe battery in your key may be getting low and needs replacing.
Feb 25, 2013 | Cars & Trucks
It terms over but don't start i think it's the immobiliser
The imobillizer disables the signal to the injectors.
Dec 22, 2011 | Cars & Trucks
I HAVE CHANGED THE IGNITION ON MY DAEWOO ESPERO CD 1998. NOW THE CAR WONT START. I SUSPECT IT IS THE IMMOBILISER THAT IS CUTTING THE ENGINE OUT. I HAVE PUT ON A UNIVERSAL IGNITION SWITCH SO THE...
Hi There.
it may be the immobiliser,,, and then it may be that you need the ignition key code and/or ECU that goes with that particular model
May 03, 2011 | 2000 Daewoo Korando
The Immobolizer for my hyundai getz is not working - I changed the batteries, but no difference. Is there a way to override the system?
dear friend-i believe your immobiliser went into sleep mode,as i have no idea if you have a high spec or normal unit,if you have a single button on your remote it is a high spec,this needs to be recoded,if it is two buttons press both buttons together and wait for the bleep,then it should be active.
Jun 16, 2009 | 2001 Hyundai Accent
Need to disable the immobiliser on a starwaggon
google this:disable the immobiliser on a starwaggon
Mar 27, 2009 | 1989 Mitsubishi Starion
Scenic non start
Hi
I wouldn't have thought the ECUs would be interchangeable due to the immobiliser. Thinking about it, a fault with the immobiliser would cause the lack of spark and noid. I know they usually also disable the starter motor as well, but a fault would change the way it responded.
I think a computer is needed here to live scan the ECU and see exactly what the little blighter is playing at before you go to the expense of an ECU.
Regards
Geordie
Jun 16, 2008 | Renault 181 Cars & Trucks
Network Engines, Inc. (SYS-NEI100-000) Firewall Logo
6,433 people viewed this question
Top Network Engines, Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Network Engines, Inc. Computer and Internet Expert? Answer questions, earn points and help others
