Question about GE Energy Star WCVH6260F Front Load Washer
Clothes wet, doesnt spin fast
Clothes are soaking wet. Pulled the filter and cleaned. It had allot of stuff in it. Ran a quick wash cycle and the unit is not spinning fast, nowhere near what it spun at before. When changing spin speeds, it is useless. Checked filter again, everything looks good. Is the dirty filter and slow spin speed related or just coincidence
  • 3 more comments
  • JuddGA Oct 31, 2007
    Problem solved. Pretty stupid of us.
    Seems like the original problem was the filter was clogged. Then when the clothes were soaking wet, most items were removed as they were light and didnt hold much water and thrown into the dryer. The only thing left was a small blanket which caused the washer to be unbalanced and not spin at full speed.
    Once the blanket was taken out the washer worked fine.
  • Anonymous Mar 14, 2014
    washes fine starts spin cycle makes a clunk sound n slows down then will start spin cycle again but doesnt feally spinn fast enough to get water out of cloths all the way replaced belt not a bunch of fiber around snubber disc ??
  • Anonymous Mar 20, 2014
    Hi the spinning cycle is like not long enough and the barrel vibrates allot then the washing is still wet please help got the machine already for 10 yrs very good machine
  • Anonymous Mar 23, 2014
    Doesn't ever get get up to speed when spinning. Appears brake keeps coming on and slows it down. Belt is in good condition and we cleared drain tubes, and checked pump.
  • Anonymous Mar 29, 2014
    on wma54Where to find filter
  • 146 Answers
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Posted on Oct 31, 2007
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Wont spin
have you cleaned the filter
if you have
change the motor brushes
Mar 10, 2014 | Hotpoint Aquarius WD63 Front Load...
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
1,086 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
